01-22-2011, 01:19 PM | #1 |
Bolts instead of Stud's?
Is it OK to use bolts instead of Studs on 59AB to mount Main bearing caps. I think the 8BA uses Bolts, and somehow the studs have been lost over the years, And here in Metricland its hard to get the nonmetric studs.
And i cant find them at Mac's |
01-22-2011, 07:26 PM | #2 |
Re: Bolts instead of Stud's?
Lars, I just salvaged the studs out of a 21 stud motor, if they are the same as what you need, they're yours for the cost of postage. Have the nuts too.
I can measure them if that would help. Mart. |
01-22-2011, 09:12 PM | #3 |
I'm using bolts on main caps on a 59AB I'm in the middle of now, cannot see a reason not to... Karl
01-22-2011, 09:56 PM | #4 |
Canadian C69A engines [pre 8BA series] used bolts on their mains. Brian
01-22-2011, 11:16 PM | #5 |
I once owned a nos 59 ab block that had bolts instead of studs.
03-18-2011, 11:03 AM | #6 |
03-18-2011, 11:39 AM | #7 |
I use grade 8 head bolts on about all my 59 engine. I bye them at a fastenal place, there kind of gold color. The only differance is they have 5/8 heads. I use grade 8 flat washer. I've never used bolts on main caps but cain't see why not. Walt PS, you can bye chrome acorn nut covers for the 5/8 head bolts.
03-18-2011, 02:30 PM | #8 |
Walt,
On choosing the bolts, how much thread depth do you allow for in the block? Thanks, Ralph |
03-18-2011, 03:15 PM | #9 |
The rule of thumb is a Diameter ans a half the main bolts are 1/2 -13 so that works out to about 9 threads min. Check for bottoming use a flat washer not a lock washer torque to 95/ ft/lbs. I don't use studs for heads either, use a grad 5 bolt with a min fof 7 threads and torque to 45 ft/lbs. I'm not saying this is the only way to do this, just the way I did it for years. Also re torque head bolts afte at least 3 heat cycles
03-19-2011, 09:18 AM | #10 |
Thanks Ron,
Do I need to put any sealer on the threads? Especially the ones that go into the water jacket? |
03-19-2011, 10:05 AM | #11 |
Use permatex aviation sealer on the bolts works very well and doesn't harden also works as a thread lube when torquing.
Ronnie |
03-19-2011, 11:48 AM | #12 |
Yup!
03-19-2011, 12:52 PM | #13 |
I bought ARP (pricey) studs and nuts for my aluminum heads at the recommendation of Red Hamilton (Reds Headers). Guess I overshot it.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
03-19-2011, 01:48 PM | #14 |
I put ARP bolts in the mains of my 8ba....dont know if there the same for 59's
03-19-2011, 02:17 PM | #15 |
YES us bolts, H & H flathead, in southern Calif, made the main center strap for my rebuild with bolts, A good sorce for bolts, and all flathead stuff. AT>> FLATHEADS-FOREVER.COM ... OR 818-248-2347.... OLD....BILL
03-20-2011, 06:41 PM | #16 |
Is this it? Just so happened I had a couple cans of this someone gave me.
03-20-2011, 07:30 PM | #17 |
Yup that's the good stuff it works
Ronnie |
03-20-2011, 10:26 PM | #18 |
If you go to an industrial supply shop you can buy grad 8 bolts for a fraction of what AARP sells them for, I bought 16 3/8 NF and 6 1/2 nf nuts and 6 hardened steel washers for 6 dollars.
