Old 02-02-2013, 10:42 AM   #1
tpenty1
Default 37 trunk lid arm (spring)
Can't find this spring anywhere! Does anyone know if there is a reproduction made or has one I could purchase? I have a Club Cabriolet but assume all 37's used the same trunk lid spring.
tpenty1 is offline   Reply With Quote
Old 02-02-2013, 11:26 AM   #2
37 Coupe
37 Coupe's Avatar
Default Re: 37 trunk lid arm (spring)
Ford definitely did not have a better idea for a trunk support in 1937. They used at least two types that I know of but only one with the spring a clockwork type spring. The worst part is the 1937 Ford trunk lids in 1937 were getting a little bigger and heavier but engineers decided a single support or spring should be able to support it .Took a year or two later that they finally figure two was better than the one. My coupe was a very low mileage car and the support was bent and broken in two pieces but spring was okay and I was able to fashion new arms for it. Mayby you could use the clockwork springs from later arms,39-40 or even up to 1946-1948 by buying a good used one or a Drake repro. Mayby a supplier like www.restorationspecialties.com has just the spring. In ten years of Ebay watching I have only seen one or two original 1937 spring type trunk lid holders show up,usually the non spring ones do.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 08-24-2013, 11:52 AM   #3
the hump
the hump's Avatar
with a very little modification, the trunk lid holder off of a 37 olds sedan works very well, it is spring loaded both directions
the hump is offline   Reply With Quote
