Old 04-18-2014, 10:25 PM   #41
Old Henry
Old Henry's Avatar
Default Re: Water leaking around oil pan bolt on 59A
Originally Posted by 37 Coupe View Post
Where did you get your information on this?
Early Ford V8 Club site: http://www.earlyfordv8.org/forum/vie...=18&Topic=2180 and: https://www.fordbarn.com/forum/showthread.php?t=107571
Old 04-19-2014, 09:02 AM   #42
Old Henry
Old Henry's Avatar
Originally Posted by 40cpe View Post
maybe I missed a post with an update, but how is the clutch chatter and the vibration?
After resurfacing the flywheel and replacing the clutch disc, pressure plate, and throw out bearing, the chatter is still there the same as before. Just the nature of the beast I guess. Not too big a deal. I've pretty much learned to all but eliminate it by the way I use the clutch.
The vibration was caused by my totally worn out U-joint. Replaced that and it is gone.
While the transmission was out I installed a thicker spacer so now my syncro works great that wasn't before.
Thanks for asking.
