Old 07-14-2015, 05:08 PM   #1
4550stally
Default clutch adjustment
Hi, new to the site i have a 1941 1-ton the clutch grinds getting it into 2nd gear and when you've stopped with clutch in, and in gear it whats to keep going forward, i know about the adjusting arm clevice but do i turn it clockwise or counter clockwise[ new clutch] any info would be helpful. thanks
4550stally is offline   Reply With Quote
Old 07-14-2015, 07:30 PM   #2
TomO
Default Re: clutch adjustment
Adjust the clutch so the the pedal has about 3/4 free play before the throwout bearing contacts the pressure plate fingers.
It sound like you need to reduce the free play.
Your truck may not have synchronizers in the transmission and you will have to double clutch in order to shift into second gear.
TomO
TomO is offline   Reply With Quote
