Old 02-24-2013, 02:23 AM   #21
ken ct
Default Re: 1938 1939 ford trucks
Originally Posted by Lawson Cox View Post
For $100.00 bucks I wouldn't care if it was 38 or 39. Jump on it if you can even recognize it as a truck. lol
I agree with you Lawson for a $100 what diff does it make wether a 38 or 39 buy it. ken ct.
ken ct is offline   Reply With Quote
Old 02-24-2013, 02:26 AM   #22
Lanny
Lanny's Avatar
38express,,,,,,,, msinclair32 has been waiting patiently at his 'puter
over 2 1/2 years for you to dig up this old thread.
I think he's trying to say thanks.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 02-24-2013, 09:39 AM   #23
oldandtired
The 39 windshield is the same size as a 37 but they are not the same frame. The '37 separates in the middle on the sides and the '39 separation point is not the same place. I do not know if the pedal assembly on the one-ton is the same as the pedal assembly on the 1/2 ton. Check the part number on the pedal assembly and see if it has a "T" as part of the part number. Looking at the pictures, it looks like a 1 1/2 ton. Maybe you could find the serial number on the frame and post it?
oldandtired is offline   Reply With Quote
Old 02-24-2013, 07:54 PM   #24
flat-v8
flat-v8's Avatar
I bought this '38 PU for $600, it was in great condition! But I sold the body and just kept the frame and running gear, today a '36 sits on that frame.
flat-v8 is offline   Reply With Quote
Old 02-24-2013, 08:49 PM   #25
brien
brien's Avatar
For $100 you could part it out and likely earn 5 to 10 times the money, likely much more...that is if you believe in Capitalism...Looking at your pics, you have a Cab likely worth $500 The grille, though bent up, a $100 easily...The frame, easily, a few hundred ..the running boards, likely $300 the pair since thehy don't look rusted out or bent up. The fender I can see needs some welding but I don't see any rust where it attaches to the body...Fenders: $250 each ..Motor? BONUS
Good luck
brien is offline   Reply With Quote
Old 03-08-2013, 05:08 PM   #26
FlatheadWillie
FlatheadWillie's Avatar
Isn't the cab totally different? Or is that just from 37-38, not 38-39?
FlatheadWillie is offline   Reply With Quote
Old 03-09-2013, 12:52 AM   #27
JM 35 Sedan
JM 35 Sedan's Avatar
[QUOTE=Lanny;598689]38express,,,,,,,, msinclair32 has been waiting patiently at his 'puter
.[/QUOTAE]
Lanny, I like your sense of humor, lol
John
Old 03-09-2013, 06:43 AM   #28
39portlander
39portlander's Avatar
RDRR, about 3 week's to early. Save this stuff for April 1st.
39portlander is offline   Reply With Quote
Old 03-09-2013, 09:16 AM   #29
malpais
malpais's Avatar
Default Since 1938 1939 ford trucks came up......
There seems to be very little activity in the 38-39 social group, or am I missing something.?
Thanks,
Gordon
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes..
malpais is offline   Reply With Quote
Old 10-01-2013, 04:46 PM   #30
tallrick
tallrick's Avatar
I saw a thread here about seats in a 1938 pickup and now I can't find it. Darn. I am trying to figure out how the seat backrest is suspended. My truck has 2 hinges attached to the bottom that are hooked to the back but this doesn't seem right. I have to remove the whole assembly to get underneath the seat, very awkward. Someone said that their seat was attached at the top on a hinge under the back window which makes more sense than the way mine is done. Any help would be deeply appreciated. Thanks, tallrick.
tallrick is offline   Reply With Quote
Old 10-01-2013, 07:50 PM   #31
V12Bill
V12Bill's Avatar
My 39 seat back is hinged at the top. Then you can lift the seat bottom to gain access to the jack and tools under the seat. However, my pickup was originally a stake bed and the gas tank is under the seat. The 38 - 39 pickup seats that I have seen are one piece and the seat slides back and forth to only 2 or 3 positions. The gas tank is in the rear and the filler is through the left rear fender.
V12Bill is offline   Reply With Quote
Old 10-02-2013, 06:29 AM   #32
Dec211975
Here are a couple of posts I think might help
https://www.fordbarn.com/forum/showth...t=seat+plywood
Regards,
Brian
Dec211975 is offline   Reply With Quote
Old 10-02-2013, 06:30 PM   #33
tallrick
tallrick's Avatar
thanks very much to the both of you. now I have an idea of what it should look like. It appears i have the correct pieces, thanks again. tallrick
Old 10-02-2013, 06:36 PM   #34
39portlander
RDRR Hey Lanny, its happening again.
.[/QUOTE]
Old 10-02-2013, 07:42 PM   #35
Lanny
Lanny's Avatar
This popular old thread just keeps coming back to life, like Elvis, it's timeless.
Old 10-02-2013, 08:48 PM   #36
41panelmark
41panelmark's Avatar
Cant wait to hear more and see some photos.
41panelmark is offline   Reply With Quote
Old 10-02-2013, 09:21 PM   #37
Stewart
Came acrost a 1939 1 ton this year that I assume was a custom of delux model. It had the ashtray in the center of the dash, sliding rear window, locking glove box door chrome windshield frame and plated grill, and the hood support was a spring loaded arm simular to the 1942 hood spring. I have already sold it to a father son restoration project.
Stewart
Stewart is offline   Reply With Quote
Old 10-06-2013, 06:40 PM   #38
tallrick
tallrick's Avatar
another interior question. above the doors there is a strip that runs front to back about 18 to 20 inches long. i think they help hold the headliner in. if any one has a picture of them i would sure like to see it. i have looked around for a set and no luck, so will try to fab my own. thanks. tr
Old 10-06-2013, 09:09 PM   #39
malpais
malpais's Avatar
Rick, mine are longer and go down behind the door also. Beads will make it hard to make, I would think......
See photos
Gordon
Old 10-07-2013, 11:06 AM   #40
tallrick
tallrick's Avatar
malpais, you are correct, that double bead complicates my idea. your pictures will be a big help in my search though so, many thanks. swap meet in portland next month, and i will scrounge through the boxes with photos in hand. thanks again, tr
