Old 06-13-2010, 12:03 PM   #1
Gary in Mozarks
Gary in Mozarks's Avatar
Default Replacing axle seals 39 ford
I pulled the hubs off both of the rear ends I have and found that both of them had grease and oil all over the drums etc. Looks like its a common problem.
Any special tricks to replacing the rear axle seals?
Anything else I should do while I am in there?
Whats the procedure for pulling the rear axles out?
Side note, My new economy hub puller lasted through 3 hubs .
It looks like I pretty much stripped out the threads on one side of the hub puller on a really tight hub. Anyone else had one fail? I will probably rethread it to 1/2x20
Gary
Gary in Mozarks is offline   Reply With Quote
