Old 01-30-2011, 06:32 PM   #1
olracer66
olracer66's Avatar
Default I need Simca "V8-60" help
Hi Guys,
My machine shop called me (knowing I do V8-60 stuff) asking if I had any info on the Simca / Vedette "60". I don't. They want to know where in the world to get the rod bearings for that engine. I was told the rod bearings appear to be 1.753 insert bearings. Can anyone help with more detailed info? Thanks!
olracer66 is offline   Reply With Quote
Old 01-30-2011, 07:54 PM   #2
oldwhizzer
Default Re: I need Simca "V8-60" help
I have some NOS simca parts and bearings with dealer books . I will try and look this week. ow
oldwhizzer is offline   Reply With Quote
Old 01-30-2011, 09:51 PM   #3
av8paul
av8paul's Avatar
Originally Posted by olracer66 View Post
Hi Guys,
Post this question on the chevybarn.com. they have a non-chevy fourm. David Dunbar seems to have a handle on the simca v8 60. He owns many of them.
If it's too loud,
you're too old.
av8paul is offline   Reply With Quote
Old 01-31-2011, 04:57 AM   #4
ventilo
http://www.depanoto.fr/ is a good source for SIMCA V8 spares
ventilo is offline   Reply With Quote
Old 01-31-2011, 01:23 PM   #5
TJ
TJ's Avatar
If you are a V-8 Club member use your roster and look up Doug Clem in Nevada. He has put Simca heads on a V-8 60 andhas some good knowledge of Simca stuff.
Old 02-01-2011, 06:41 AM   #6
Greg in Jax
Greg in Jax's Avatar
I have been tracking down parts for an acquaintance in NZ who is putting together a Vedette engine, and he got stuck on the same part. Rod bearings are available in France but they are $500 - 800 a set. An option is to use BMC 1098 or 1275 (AH Sprite, MG Midget) rod bearings. The width is very close and that is not the important measurement, they are staked bearings, and it would only require regrinding the crank to the standard BMC big end sizes. Vedette standard crankpin diameter = 1.7455 - 1.7555, BMC is 1.6254 - 1.6259. That means that standard BMC big end bearings are .1191 - .1196 undersize for the Vedette. IThere are many sources for the BMC bearings.
Greg in Jax is offline   Reply With Quote
Old 02-01-2011, 09:49 AM   #7
Charlie ny
'66',
What AV8 says.....Dave Dunbar in Cape Cod may have your
answer...781`585 3755.
Charlie ny
Old 02-01-2011, 12:55 PM   #8
olracer66
olracer66's Avatar
Thanks guys!!!!! All good info. Charlie, I'm in touch w/ David. Greg & Ventilo, I am passing your info to the shop guys. I hope I can be as helpful for the next request.
OlRacer66
Old 02-02-2011, 01:20 PM   #9
rusiq
This SIMCA was produced in Brazil from 1959 to 1968.
In Brazil there are many parts for these engines.
It was used by Simca in France until 1961 for cars and even later in Brazil (1968) by Simca / Chrysler. Until 1966 for versions Simca then until 1968 with a head akin to the Ardun (OHV conversion)
rusiq is offline   Reply With Quote
