Thread Tools Search this Thread Display Modes
Old 08-06-2012, 11:18 PM   #1
THR1LL3R
THR1LL3R's Avatar
Default SBF Gurus step inside
I have two SBF 302s Ive been messing with and I am having water pump issues. I have a 1974 Van 302 v-belt with a 3 bolt crank pulley and a passenger side exit water pump. Next I have a 1990 mustang 302 with serpentine belt, 4 bolt crank and reverse rotation driver side exiting water pump. I originally wanted to install the Mustang 302 in My 50 Ford using the v-belt parts from the van motor. The Van has a 3 bolt crank pulley as the mustang has a 4 bolt... what years had the 4bolt v-belt crank and where could I find them??...in addition to the passenger exit,the van water pump shaft is shorter than the mustang reverse flow....(see pic)
Does anyone know of a regular flow water pump with driver side exiting that would fix the mustang motor? In the last few weeks I found a Ford F1 to but the van motor in but I would also like to but a driver side exiting pump on that one too to work with the radiators I have. Sorry if I have confused anyone and need to do more explaining lol..
Thanks Guys
THR1LL3R is offline   Reply With Quote
Old 08-06-2012, 11:27 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: SBF Gurus step inside
You confused me when you said "I have two SBC 302s"... and one of them is from a Mustang??
Y-Blockhead
Old 08-06-2012, 11:35 PM   #3
THR1LL3R
THR1LL3R's Avatar
i have no idea what happened there,got it right in the title.Thanks for the help...
Van 302
mustang 302
Old 08-07-2012, 08:42 AM   #4
KULTULZ
KULTULZ's Avatar
Post Re: SBF Gurus step inside
See if this helps- http://www.jalopyjournal.com/forum/s...d.php?t=303600
Complicated Subject. You also have to match timing covers to the pump style. FORD RACING PARTS also offers a damper that is drilled for both 3 & 4 bolt pattern if that will help.
MEL DIVISION 1958/1960
MERCURY-EDSEL-LINCOLN
KULTULZ is offline   Reply With Quote
Old 08-07-2012, 08:49 PM   #5
34pickup
34pickup's Avatar
Check into an older Mustang water pump, like a 1967 or so. If I recall, they had the drivers side dump.
I thought my new girlfriend just had a lot of tattoos, until she took a bath.
34pickup is offline   Reply With Quote
Old 08-07-2012, 09:33 PM   #6
THR1LL3R
THR1LL3R's Avatar
Ive read that thread and it makes my head hurt. This is turning out to be a nightmare,really just want to swap to something common if im on the road incase I break down. Guess Ill by an early mustang and start from there. Too bad theres not a water pump year chart.
Old 08-07-2012, 11:09 PM   #7
JohnSunliner
JohnSunliner's Avatar
I recently needed one for a 79 302 I rebuilt. I just went to NAPA and got one for about $80.
JohnSunliner is offline   Reply With Quote
Old 08-08-2012, 01:31 AM   #8
KULTULZ
KULTULZ's Avatar
It is a lot of confusion. That one post in the thread I showed gets pretty close to the correct answer. There is a book called rebuilding SBF or something to that nature that does have the complete interchange information.
I was going to do a study on this some years back but I got sidetracked with MEL. Let me try and find that book.
As these engines have been around since 1962, they had a lot of upgrades over the years (including 5.0L tech).
Old 08-08-2012, 02:01 AM   #9
KULTULZ
KULTULZ's Avatar
Here you go- -CLICK ON THIS-
Old 08-08-2012, 10:33 PM   #10
THR1LL3R
THR1LL3R's Avatar
Thanks!
Search this Thread:
Advanced Search
