12-09-2010, 11:10 AM | #1 |
V-8 freezing concerns?
Guys, I recently bought a non-running, but free turning V-8 from warm California. It's going to get cold here in Chicago in the next few days - real cold. I doubt there is any antifreeze in the block. Anything you can think of that I can do to prevent damage or just hope for the best?
The car cannot be moved inside, thanks.
John Mc Crystal Lake, IL '39 1/2 Ton Pickup '56 Lincoln Capri Hardtop '77 Lincoln Town Coupe |
12-09-2010, 11:13 AM | #2 |
Re: V-8 freezing concerns?
John Mc: Be on the safe side. Drain the radiator and block. Tom..
12-09-2010, 11:28 AM | #3 |
Will do, thanks.
12-09-2010, 11:34 AM | #4 |
When I was a kid I had a 429 Ford Mercury Marquis, I had a heck of a time starting that old gal in the cold, I ran a power cord that I set up on a circuit breaker in case of trouble, put a 75 watt light bulb in the engine bay hanging in a nice clear spot so as not to cause a fire and put a big moving blanket on the hood. She always fired up. There may be a safer way to do this, maybe an infrared heater or something but it may be worth while to do.
12-09-2010, 12:43 PM | #5 |
When I lived in Wisconsin I used a type of block heater or warmer in the winter. I think it may have been some type of an "electric" dipstick that kept the oil warm overnite. Worked great and not expensive. http://en.wikipedia.org/wiki/Block_heater
12-09-2010, 01:04 PM | #6 |
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
12-09-2010, 07:10 PM | #7 |
My father used one of those dipstick heaters for 2 years. On the second year the tractor cought on fire and burned up. The insurance company fixed it and dad installed a block heater.That was probably 30 years ago, and Dad is gone now,but it is still working for me. Marv
12-09-2010, 11:27 PM | #8 |
If you can not get the drain on the radiator open, just cut a hole in the bottom radiator hoses, both of them.
Chris |
