Old 06-20-2013, 08:58 PM   #1
waterboychuck
waterboychuck's Avatar
Default Cowl to fender rubber on 48 F1
I'm in the process of putting my 48 F1 together and am having a problem of where the cowl to fender rubber starts and ends. There were no instructions with the rubber parts when I got it. Does anyone have any photos so I can do this job right?
Thanks, Chuck
waterboychuck is offline   Reply With Quote
Old 06-20-2013, 09:39 PM   #2
okiedokie
okiedokie's Avatar
Default Re: Cowl to fender rubber on 48 F1
Here is how I did the ones I just installed on my brothers F1. Hope these help.
okiedokie is offline   Reply With Quote
Old 06-21-2013, 12:25 AM   #3
Thaplumbr
Thaplumbr's Avatar
That looks real close to what I have on my 48 as well,if I could figure out how to do pics on regularly on these forums someday I would have posted mine as well
Thaplumbr is offline   Reply With Quote
Old 06-21-2013, 08:55 AM   #4
toby
toby's Avatar
Here's how I installed them on my F1
toby is offline   Reply With Quote
Old 06-21-2013, 09:25 AM   #5
mtflat
mtflat's Avatar
I cut mine like toby's at the bottom. I like the wrapped look of okie's but I'd be afraid of trapping water in the bottom tuck - a dry climate would be different.
mtflat is offline   Reply With Quote
Old 06-21-2013, 12:39 PM   #6
waterboychuck
Those photos helped a lot.
Thanks, Chuck
Old 06-23-2013, 09:43 AM   #7
GreenMonster48
GreenMonster48's Avatar
What are you guys using to keep the rubber in place? Looks like originally they were put in with heavy staples. Did you have to remove the fenders or were you able to tuck them in? Thank you
GreenMonster48 is offline   Reply With Quote
Old 06-23-2013, 11:37 AM   #8
Ross F-1
Ross F-1's Avatar
I guess there's a third way to do it. I ran mine all the way down to the bottom of the fender, below the running board, and the little filler pieces at the front of the running boards fit right into it.
I didn't use any glue, it pretty much snaps onto the edge of the fender. Once the fender is tightened, it ain't going anywhere.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-23-2013, 12:38 PM   #9
okiedokie
okiedokie's Avatar
Wish I had done it your way Ross. Much nicer look.
