Old 10-17-2011, 03:30 PM   #1
james.heider
james.heider's Avatar
Default 12 volt or 6 volt coil how to tell difference
I have several coils that are either 12 volt or 6 volt. They are not marked and I was wondering how you can tell the difference?
There must be an ohms reading that would give some indication.
Any help would be appreciated. I don't wanrt ot just hook them up to a 12 volt battery and burn them out if they are 6 volt.
james.heider is offline   Reply With Quote
Old 10-17-2011, 03:57 PM   #2
Dave in Boise
Dave in Boise's Avatar
Default Re: 12 volt or 6 volt coil how to tell difference
You won't burn out the coils, but here is an easy way to tell..
Hook 12v power to 1 side of the coil, and then check the voltage on the other side.. H
(hook to + and check output on - for instance, the polarity for the test is not important and won't hurt either way)
_+_[]_-_
|______|
12v through a 12v coil will still show 12v when it comes out the other post of the coil, however a 6v coil will drop the voltage to 6v.. I have used old 6v coils as voltage reducers before for intermittent items in a 12 v system, like a horn or other item
- Dave in Boise
Dave in Boise is offline   Reply With Quote
Old 10-17-2011, 06:01 PM   #3
james.heider
Thank You Dave.
Old 10-18-2011, 12:28 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
You need to connect an amp meter in series with the coil and 6 volt battery. A 6 volt coil will draw 4 amps.
Old 10-18-2011, 04:15 AM   #5
Jim/GA
Jim/GA's Avatar
If you have an accurate ohm meter, reading across the posts of a 12 volt coil should be about 3 ohms. A 6 volt coil is about half of that. It is not an exact number, but close enough that you can tell 6 from 12 volt.
Or, doing what Tom says, a 12 volt coil will flow about 2 amps if connected to 6 volts. Instead of an accurate ohm meter, you need an accurate ammeter (that can tell the difference between 4 amps vs. 2 amps).
Jim Cannon
"Have a Model A day!"
Old 10-18-2011, 08:16 AM   #6
ldj1002
There will be a difference in test results in a 12v coil that is to be used with a resister than one that doesn't need a resister. Also a 12v coil that doesn't need a external resister will test very close to a 6v coil. Would that 12v coil be ok on on a 6v car?
ldj1002 is offline   Reply With Quote
Old 10-18-2011, 08:49 AM   #7
MrTube
MrTube's Avatar
I would speculate this is the only valid test I've seen so far. Testing a coil that has a resistor in series with it without one end connected should always show whatever the input voltage is as there will be no drop across the resistor or coil.
That and Tom usually knows his stuff
MrTube is offline   Reply With Quote
Old 10-18-2011, 09:16 AM   #8
RonC
RonC's Avatar
12 volt coils are actually 6 volt coils with a resister connected in series within the primary circuit usually internal to the coil. That fact allows you to check the ohms across the primary terminals to see what the resistance is of the coil. As mentioned above a 6 volt coil should have less than 2 ohms and a 12 volt coil will have more closer to 2.5 to 3 ohms of resistance
RonC is offline   Reply With Quote
Old 10-18-2011, 09:38 AM   #9
MrTube
MrTube's Avatar
I agree however, how many people here own an ohm meter which is known to be accurate within 1 ohm? Sure a cheap analog meter will show a difference between a 6v coil and a 12v one, but what if someone has no reference?
Old 10-18-2011, 09:58 AM   #10
james.heider
How many amps does a 12 volt coil draw using a 12 volt battery?
Old 10-18-2011, 10:38 AM   #11
RonC
RonC's Avatar
That would be a problem. I assume we are talking about old coils laying around of questionable conditon and you don't want to buy a decent ohm meter just to see if you have 6 or 12 volt coils? In that case I would recommend tossing the coils in the trash and buying a new one 6 volt coil at autozone for only $16.00.
Old 10-18-2011, 10:41 AM   #12
RonC
RonC's Avatar
The amps would be the same. 4 amps
Old 10-19-2011, 12:42 AM   #13
Tom Wesenberg
That coil should give you enough spark to run the car, but it may be a bit weaker since you mentioned that it has an internal resistor. A better choice would be a 12 volt coil that needs an external resistor. Then when it's run on 6 volts you'll get a hotter spark than the 12 volt coil with the internal resistor.
I find 6 volt coils at most swap meets and don't recall buying a bad one yet. That's because so many coils are needlessly replaced.
Old 10-29-2011, 08:47 AM   #14
ldj1002
OK, I didn't make myself clear. If I have a coil and all it says is 12v or nothing, How can I check it to determine if I use it on a 12v as is or put a resistor in line?
Old 10-29-2011, 09:11 AM   #15
Jim/GA
Jim/GA's Avatar
Read across the primary posts with an ohm meter. If it reads about 3 ohms, you can use it on a 12 volt car without an external resistor. If it reads about 1.5 ohms, you need an external resistor.
Jim Cannon
Old 10-29-2011, 10:52 AM   #16
ldj1002
Thanks very much
Old 10-29-2011, 04:50 PM   #17
lazlobassett
lazlobassett's Avatar
Is the mallory available for 6 volt? I'm about to put a B motor w OHV & t-5 in my '31 roadster. It's hard to sleep nights !
LazloBassett
Because a bottle in front of me
IS
better than a frontal lobotomy
lazlobassett is offline   Reply With Quote
Old 10-30-2011, 08:15 AM   #18
lazlobassett
Oops! Wrong thread.
LazloBassett
IS
Old 10-30-2011, 10:35 AM   #19
Jim/GA
Jim/GA's Avatar
you can delete any of your posts. click on the EDIT button and then DELETE.
Jim Cannon
Old 10-31-2011, 09:49 PM   #20
Ice man
Ice man's Avatar
NO such thing as a 6 volt or 12 volt coil. You need to match the impedience of what your working with. Iceman
Ice man is offline   Reply With Quote
