Old 12-24-2012, 02:04 PM   #1
duffer
duffer's Avatar
Default 1930 tools on ebay
Are these the correct tools for 1930? Is that an original bag or remake? Thanks
http://www.ebay.com/itm/130822918027...84.m1423.l2649
duffer is offline   Reply With Quote
Old 12-24-2012, 02:25 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 1930 tools on ebay
Not all the tools are Ford(S shaped wrench), most look to be mid 30s V8,--crank handle, head/spark plug wrench, pliers ---the adjustable wrench could be, the bag needs closer inspection.
Old 12-24-2012, 03:11 PM   #3
jmeckel
jmeckel's Avatar
The adjustable wrench, and "spoon shaped tire iron / brake adjustor", are model A Ford tools, the plyers, straight open end wrench and bag maybe but would need to have a much closer and better look to kow. the others are not.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 12-24-2012, 04:01 PM   #4
juke joint johnny
juke joint johnny's Avatar
Have a look in the Judging standards Only the tire iron and the adjustable are for the A Might be an old bag . These tools can still be found at swap meets & flea markets for a $1or 2 . the standards tells you what to look for . IMO its allready selling for more than its worth.
John Cochran
juke joint johnny is offline   Reply With Quote
Old 12-24-2012, 09:31 PM   #5
160B
160B's Avatar
The pliers are not Model A ford. The bag could be Model A if it has the correct snaps, and the photo does not provide enough detail to tell for sure.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 12-24-2012, 09:39 PM   #6
Jerry Parr WI
Jerry Parr WI's Avatar
The lugnut/crank handle is a V8 era version. The crank is missing the extension. It's length determines the year and engine.
Jerry Parr WI is offline   Reply With Quote
