Old 01-08-2015, 04:23 PM   #1
ursus
Default Frame Weight
Can anybody provide me with the total weight of a bare Model A frame? I have an offer to save one from the scrap heap but will have to lift and load it myself. Thanks!
ursus is offline   Reply With Quote
Old 01-08-2015, 04:32 PM   #2
Joe K
Joe K's Avatar
Default Re: Frame Weight
Gosh, it can't be more than 100 lbs.
I have two frames that I used a hoist to bring up to the top of the barn, and moved them from the hoistway to where they are stacked - by myself.
One of these has the running board brackets attached, which complicates getting past all the rest of the um, stuff up there.
Two full grown adults should have NO problem. You yourself only slightly more.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 01-08-2015, 05:46 PM   #3
Great Lakes Greg
Great Lakes Greg's Avatar
I carried mine from the house down to the barn after a good breakfast.
Great Lakes Greg is offline   Reply With Quote
Old 01-08-2015, 05:53 PM   #4
Big hammer
Standing in the middle of the frame, find the balance point, grab the rails, stand up, when you place it on truck bed by rotating you wrists, set other end down, step out and pick up, slide into truck bed. Sit down and have a cold or warm drink. No help needed :-)
Old 01-08-2015, 06:12 PM   #5
flatford39
That is exactly how I move them around by myself. I am 64 years old and 5'7" and have no problem doing this. When you grab the rails just remember to lift with your legs and not your back and you will be fine.
flatford39 is offline   Reply With Quote
Old 01-08-2015, 06:18 PM   #6
SeaSlugs
SeaSlugs's Avatar
yea 2 of us can pick up and move a 131" wheelbase long AA frame (beeier in all aspect) and wasnt too bad. Had some difficulty in rotating it 180* but we did it!
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-08-2015, 06:56 PM   #7
ursus
Thanks for the responses! Over the years I have Picked up and carried or moved every single part of the Model A Ford except the frame and had no idea of its weight, hence the question.
Old 01-08-2015, 09:34 PM   #8
hardtimes
hardtimes's Avatar
Hey ursus,
I'm guessing couple/three hundred lbs. If you have a trailer or long bed (8ft) truck, you can get one end into bed easy enough. Then just pick up other end and push ! I've done it this way (8ft truck bed) by myself. Put weight belt or some sort of support around gut...if old guy !
If you can muster wife and/or some guy to help, piece of cake, eh !
hardtimes is offline   Reply With Quote
Old 01-08-2015, 10:49 PM   #9
Roadster62
Roadster62's Avatar
I'm 64 and an even 6 foot and moved an AR frame this morning no problem. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
