11-26-2013, 08:38 PM | #1 |
1958 Ford speedometer
Does anyone know where I can get a functioning 1958 Ford speedometer?
11-26-2013, 08:45 PM | #2 |
Re: 1958 Ford speedometer
whats wrong with yours?
11-26-2013, 08:48 PM | #3 |
speedometer needle is not visible. When I spin the knob on back of speedometer CW or CCW the hand will not show, so I suppose the problem is not the cable. When I had a 1958 Ford as a teenager, I could spin the little know where cable inserts at back of speedometer and the hand would jump up from the zero MPH side.
11-26-2013, 09:58 PM | #4 |
Aren't the 57s the same??
If brains were wire, some couldn't short circuit a firefly |
11-26-2013, 10:31 PM | #5 |
Get a copy of Hemmings and look for a repairman in the Services Offered section.
Or Google Speedometer repair |
11-27-2013, 12:45 AM | #6 |
11-30-2013, 05:54 PM | #7 |
57's are the same and they show up on ebay quite often. Better choice would be to send yours out for a rebuild.
Chances are anything you buy will need a rebuild anyway. I use APT Instruments (www.gaugeguys.com) they do a great job and have a large stock of the old parts needed to fix old speedos. Pete |
08-11-2014, 04:12 PM | #8 |
Thanks everyone for the help.
08-13-2014, 02:48 PM | #9 |
x2 on ebay.i see them all
of the time.the 57 is the same but the face is black instead of white. jim |
