11-08-2011, 09:12 PM | #1 |
40 ford fender brace
I'm ready to install the front fender brace on my 40 coupe. My question is how the bottom center mounts to the front crossmember. Is it just a bolt, washer, nut or is there a spring on the bolt like the radiator mount.
Thanks, Tony |
11-08-2011, 09:49 PM | #2 |
Re: 40 ford fender brace
Spring and a bolt like the radiator mount.
11-09-2011, 09:57 AM | #3 |
I think this is correct but i also remember a piece of gasket or thick material that mounts on the cross member below the spring.....
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
11-09-2011, 06:52 PM | #4 |
Thanks, it's been a while since the car was apart
11-09-2011, 08:37 PM | #5 |
