11-19-2012, 03:41 PM | #1 |
Brake centering tool
I have a question about using the brake centering tool.... is it needed just to set the brakes so the drums can be installed ? Once the drums are installed I thought the brakes would center themselves.
Or have I just been lucky installing shoes all these years ? Never used one of these tools...are they really needed. Joel |
11-19-2012, 03:48 PM | #2 |
Re: Brake centering tool
Unless you have a floater system, they don't center themselves. Everything that I have read say's that it is a very good idea. Required.....I dont know. I don't take any chances with brakes.
Good luck
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
11-19-2012, 04:02 PM | #3 |
Even if you have the shoes arced to match the drum size, the odds of them being centered are remote. They will equalize on the rears but not on stock fronts.
It's important to note that there is more to a proper centering tool than most folks realize. The centering tool must be a micrometer of sorts OR have the ability to be sized to the drum that will be used. For example, if your drum is .043" over then the centering tool must be set to that size. If the centering tool is set too large or too small when setting up the shoes then they will no longer be centered when you properly adjust the adjusting wedge to match the drum. If you go through this exercise correctly just one time I suspect you will be amazed what you find.
http://www.abarnyard.com/ |
11-19-2012, 04:10 PM | #4 |
Marco, Not sure I understand your point. If you center the shoes around the axle, and the drum braking surface is by design centered on the axle, how does it matter if the drum is oversized?
11-19-2012, 07:01 PM | #5 |
my confusion is more fundamental than that....where exactly is there any adjustment provision within the front braking mechanism?
11-19-2012, 07:08 PM | #6 |
11-19-2012, 07:32 PM | #7 | |
Ohh jeez, ....the train has just "derailed"!! |
11-19-2012, 07:47 PM | #8 |
If your drums are turned to a larger diameter than the shoes, then they will contact in the center of the arc, not out towards the ends. This means you have a much smaller contact patch than you should. I.E. less brakes. Once the shoes have been ground to the proper dia. they need to be centered in the drum. Once centered then they can be adjusted in our out with the wedge. This only affects the drag or preset of the shoes before they are actuated. This is an exaggeration but think about it like this.... If you have a 14" rim in a 15" tire it’s only going to contact the tire's lip in one spot, not all across like it should. Even then the spot could be high or low and not on the centerline. Here is a pic someone posted here before that I borrowed. I have Barrett equipment, but this will get you by....
Good Luck
Wanted: Simmons Super Power Head Craig Likon 1931 150B Last edited by ctlikon0712; 11-19-2012 at 07:53 PM. |
11-19-2012, 08:00 PM | #9 |
If you install Flat Head Ted's floater kit the front brakes will then automatically center. The rear brakes only half center. In addition to Flathead's floaters installed in the rear adjusters, he also provides what he calls "pins" that replace the rollers that slide on the roller tracks. For each rear wheel the pins are a pair that are a mirror image to each other. Instead of a roller there is a four sided eccentric with a 1\16" difference to each side. By selecting a given side you center the other half. You need a centering tool to accomplish this. Bratton sells one that will do the job. Page 156 in their catalog, part number 2695, $44.00.
According to some literature I have seen the centering of the original rear brakes is supposed to be accomplished by bending the roller tracks up or down. Tom Endy |
11-19-2012, 08:06 PM | #10 |
This is the one I use.
Bob |
11-19-2012, 08:11 PM | #11 |
You center the front by bending the flats of the roller track up or down.
11-19-2012, 09:07 PM | #12 |
Brake shoe sizer and centering tool
This tool can be set to the radius of the drum and then used to check the shoes on the wheel and center them too. The $99 this guy is asking is too much money for it but it is a solution. The best tool for the A is the Barret Brake Doktor. This attaches to the axle and sands the shoes to size on the car. This means the shoes will also be centered to the axle. |
11-19-2012, 09:12 PM | #13 |
Kevin the only problem I see with the brake doctor is if it sands the shoes to fit the drums its not really centering them. It would cause one shoe to wear out before the other.
11-19-2012, 09:43 PM | #14 |
The tool is attached to the axle with the shoes mounted. You then turn the tool around as the disk sander sands the shoes to diameter. The shoes have to be centered as it is swinging around the axle.
The differential thickness is not much unless you put some way off hardware on the shoes. Besides, how many drive their car enough to wear out the shoes? Most cars are not driven enough to wear the brakes to the drums in less then a few years. This makes getting the center and diameter of the shoe even more important from the start. Otherwise you may take years to get full braking as the shoes wear to fit the drums. It is a royal pain in the butt to make all the brake parts give you a centered fit to the accuracy you get with the Doktor tool. Short of getting all NOS brake parts the best brakes will come from properly using the Doktor. |
11-19-2012, 09:57 PM | #15 |
But if the shoes are arced to fit the drums, then centered with a centering tool, doesn't that take care of the possible oversized drum problem?
11-19-2012, 10:12 PM | #16 |
This is the shoe grinder.
Bob |
11-19-2012, 11:14 PM | #17 |
I am going to copy Craig's econo-tools he made and give it a try.....now that it has been explained I think I understand........all these years I have always had hydraulics and did not experience the fun of mechanical brakes....and all the little tricks to them....ie. that darn emergiency brake return coil spring nightmare.
Thanks Guys Joel Rapose Chester Ca, |
11-19-2012, 11:22 PM | #18 |
700rpm, "yes" is the answer.
11-19-2012, 11:45 PM | #19 |
Yes, I agree now, I just put the drums on and they bearly turn...I think I can make a tool quickly now that I see what it needs to do.
Thanks again Joel |
11-20-2012, 12:03 AM | #20 |
Not exactly. First, the most common way to "arc" the shoes is by grinding them with an artificial center. The shoes get thin spots like other grinding methods MAY do so no gain AT BEST on the wear factor.
Second, over the decades many shops have altered the radius of the steel shoe by peening the web. These will not easily grind to your proper arc AND you have now changed the length of the shoe between it's two anchor/alignment points. Also it means it will have to push outward at a different rate than it's counterpart unless they're an exact match.
