Old 01-12-2024, 09:39 PM   #1
Ron Blissit
Default T rear spring in the rear of model a??
Will a modelT rear spring work in a modelA. looking for a softer ride in my roadster
Ron Blissit is offline   Reply With Quote
Old 01-12-2024, 09:44 PM   #2
Dodge
Default Re: T rear spring in the rear of model a??
It will with spacers on either side of the spring. The T spring is narrower. It will lower the
car a bunch also so be aware of that.
Does you car have a Roadster spring in it already? Maybe you have the wrong spring if
you think it needs to be softened up.
If it has the correct spring you can take some leaves out of it to soften it up.
Dodge is offline   Reply With Quote
Old 01-12-2024, 09:44 PM   #3
Ron Blissit
Will a model T rear spring work in a modelA ? looking for softer ride in roadster
Old 01-12-2024, 09:46 PM   #4
J Franklin
J Franklin's Avatar
Anything can be made to work with enough effort but it would be much easier to just remove a leaf from the original spring.
Old 01-12-2024, 09:48 PM   #5
Ron Blissit
Currently has a 10 leaf.I was more concerned about the shackles if they would work
Old 01-12-2024, 09:56 PM   #6
Tom Endy
Tom Endy's Avatar
Roadsters are supposed to have a 7-leaf spring, coupes & Tudors an 8-leaf spring, all others a 10-leaf spring. I suggest you find at least an 8-leaf spring and replace the 10-leaf with it.
Tom Endy
Old 01-12-2024, 09:57 PM   #7
ursus
The 10-leaf was for a sedan. The coupe had an 8-leaf and the roadster a 7-leaf. The roadster rear spring had a different (lower) profile than the others and a unique spring pack configuration.
Last edited by ursus; 01-12-2024 at 09:58 PM. Reason: Looks like Tom beat me to it by a minute!
Old 01-12-2024, 10:17 PM   #8
Joe K
Joe K's Avatar
Model A Springs of all usual layout come and go on Ebay. BUT - be sure you're getting a Model A spring - and that it has all the leaves.
More than once I've seen an "original" Model A front spring with (count 'em) six leaves. Read the description and this is from an original complete Model A and the seller is convinced this is "original."
Perhaps to him. All sources indicate that for the cars only a 10 leaf (standard) or 12 leaf (for cars of exceptional service requirement) was available from Ford.
There have been MANY substitutes made over the years including J.C. Whitney, Posie, Sacramento Ford and others. Some of these conform to the Ford drawings, others not so much.
I have spoken of a J.C. Whitney front spring of my ownership which fits the space between the spring perches perfectly, doesn't have the leaf corners "clipped", and is stiffer than you can imagine. I've considered this is one of a pair of repurposed trailer springs. It worked until I got something closer to original.
And this is not to run all of these substitutes down. Posie's springs are highly thought of in the rodder crowd which may have something to do with the unusual "lubrication pocket" built into each leaf.
So I guess the advice is "caviet emptor." Be sure you know what you're looking for and that what you're getting conforms to SOMETHING. The original Ford spring layout might be best - but you probably don't want a "mix & match."
Joe K
Shudda kept the horse.
Old 01-12-2024, 10:45 PM   #9
Pete
Pete's Avatar
It is possible to get a 100 lb. per inch spring rate with a stock spring.
This is a very soft "touring" ride good for a comfortable ride on normal streets and roads.
You have to do a lot of playing with a combination of leaves from a stock spring.
Always leave the 2 longest leaves in the combination.
Be sure your shocks are in good shape and hooked up when testing.
Be sure the individual leaves are clean of any rust and scale and sprayed with Moly Lube when assembling.
Old 01-13-2024, 03:11 AM   #10
dave in australia
Tom Endy
Do you mean Coupes and Phaetons are 8 leaf and all others 10 leaf?
dave in australia is offline   Reply With Quote
Old 01-13-2024, 03:14 AM   #11
dave in australia
A link to a fordbarn page with Marcos spring chart.
https://www.fordbarn.com/forum/showt...t=spring+chart
Old 01-13-2024, 07:06 AM   #12
springerpete
springerpete's Avatar
Check with Bert's in Denver. They will have the info and spring you need. As said above, you have the wrong rear spring now. Bill
springerpete is offline   Reply With Quote
Old 01-13-2024, 07:40 AM   #13
Tim Ayers
A few thoughts:
If you take the spring apart, a few thoughts: Feather edging all of the leaf ends that stack on the main leaf makes them glide/work so much better and gives a smoother ride.
Using a T spring does lower the rear approx. 1.5"-2". If you swap in '26/'27 T rear cross member, it gets the rear even lower.
I think the T springs looks better, but I'm a hot rodder.
Old 01-13-2024, 09:06 AM   #14
wuga
I just ordered 12 slider buttons from Posies to install in a stock rear spring. It is necessary to punch a .25" hole to receive each button. This is for my Tudor. My RPU has similar rear weight to a roadster. It had a 10 leaf and rode like a lumber wagon. This may have been necessary when it was a working truck. I got a Posies replacement and took it down to 7 leaves and it rides like a dream. By the way, as long as you don't mess with the main leaf, it will make no difference to the shackles.
Warren
wuga is offline   Reply With Quote
Old 01-13-2024, 01:25 PM   #15
su8pack1
su8pack1's Avatar
The first few minutes Of a youTube video by Strong's Garage has a video showing these guys putting a Model T spring in a Model A. The video is titled "Double Your Garage Space for FREE?!!?" I can't post a link as I don't have enough posts.
su8pack1 is offline   Reply With Quote
Old 01-13-2024, 04:40 PM   #16
Chris Haynes
Chris Haynes's Avatar
I bought a new rear spring from Posies. It has reversed eyes and lowered the car 2". It has the large Teflon buttons.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-13-2024, 05:04 PM   #17
redmodelt
redmodelt's Avatar
Because the T spring is narrower, you would also have to use spacers at the shackles.
Old 01-13-2024, 09:03 PM   #18
Randy in ca
Randy in ca's Avatar
Here's the link to the video mentioned in Post #15 where what you're considering is done:
https://www.youtube.com/watch?v=aCi5SPXkHUU
Randy in ca is offline   Reply With Quote
