Old 12-26-2010, 07:03 PM   #1
slopokpete
Default 8BA and 59AB Intake Manifold
Will an intake manifold from a 59AB fit and work on a 8BA engine?
Jeff
slopokpete is offline   Reply With Quote
Old 12-26-2010, 07:20 PM   #2
V8 Bob
V8 Bob's Avatar
Default Re: 8BA and 59AB Intake Manifold
Ths "short" answer is yes.
Old 12-26-2010, 07:25 PM   #3
slopokpete
How long is the long answer?
Jeff
Old 12-26-2010, 07:32 PM   #4
bobscogin
It bolts on, but you'll need to address the differences in the crankcase breather system .The 59A intake has a cavity over the breather tube in the valley to allow the crankcase gases to go down the front of the block and out the road draft tube. The 8BA doesn't have this cavity due to the difference in the way it's crankcase breaths. You can shorten the 59A tube to provide clearance over the tube, or install a PCV valve. Study the 8BA manifold at the breather and oil fill tube area and the differences are obvious.
Bob
bobscogin is offline   Reply With Quote
Old 12-26-2010, 07:41 PM   #5
V8 Bob
V8 Bob's Avatar
Bob
...Also fuel pump, stand and push rod are different, and carb pad is level on the 59A, 3 degree angle on the 8BA.
Old 12-26-2010, 07:47 PM   #6
slopokpete
Thanks guy for the info.
Jeff
