Old 01-02-2013, 10:23 PM   #1
lilyduck
Default Please help me ID this car
Hi there!
I'm helping out a widow who's husband died recently. He left this car in an abandoned corner of this property and she would like to get rid of it.
Here are some pictures:
https://www.dropbox.com/sh/8twvjkrzkklqnla/NODlbA-G61
What is this car? We know it's an old Ford Roadster.. Model A or B?
Is this thing worth anything?
Any tips on how to sell it? Ebay? Craigslist? Give to a scrap metal dealer?
Thanks for any help you can offer!!
lilyduck is offline   Reply With Quote
Old 01-02-2013, 10:33 PM   #2
Rowdy
Default Re: Please help me ID this car
I am seeing a Ford truck, not a roadster, maybe you gave us the wrong pic's. Nice truch though. If I had room, time and money it would be alot of fun to restore. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 01-02-2013, 10:39 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Looks like it was set up to run on propane or coal gas. That truck would sell to many rodders or restorers.
Old 01-02-2013, 10:44 PM   #4
700rpm
700rpm's Avatar
Definitely do not give it to a scrap dealer. The truck has value, maybe between $1000 and $3000, depending on several factors like rustout, whether the engine turns over, your location (which is where, by the way?), and what's there and isn't there. I'm not a V-8 guy, but it looks like it's a '32 (though the headlights look like Model A), which would make much of it very desirable. I would suggest you find a local V-8 club and make contact with the members for close-up hands-on advice.
Ray Horton, Portland, OR
Old 01-02-2013, 10:49 PM   #5
lilyduck
Wow! Thanks for all the quick help. The pictures are correct, I was just guessing that it was a roadster.
We're located in the Santa Cruz Mountains, near San Jose, the Bay Area, in Central California.
Anyone have suggestions of clubs in our area?
Thanks!
Old 01-02-2013, 10:50 PM   #6
Rowdy
Tom, I think that is the later flathead Merc carb. Definately not the original engine to the truck, waterpumps are in the block, not in the heads. Rod
Old 01-02-2013, 10:52 PM   #7
Rowdy
Definately not in my area, but several on here are close. I think it is a 32 truck judging by the grille, but could be 33-34 also, those all looked real close to the same. The 33-34 truck will have a grille simular to the 32 car, but will have 2 crank holes at the bottom. Rod
Old 01-02-2013, 10:57 PM   #8
FL&WVMIKE
FL&WVMIKE's Avatar
lilyduck .......................
Just the grille, alone, is going to be worth $300.00-$400.00. Don't let anyone talk you out of it for scrap pricing. Undamaged ones are really scarce, nowdays.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 01-02-2013, 11:01 PM   #9
Special Coupe Frank
Special Coupe Frank's Avatar
If it's a '32, then would it be a BB ?
Certainly looks salvageable !
SC Frank
Special Coupe Frank is offline   Reply With Quote
Old 01-02-2013, 11:02 PM   #10
Rowdy
Cab alone will bring $800++, light bar and headlights are decent sellers also, likely $250+ for the bar and the lights. Hard to tell much about the engine other than it was replaced, but if that is the Mercury carb I think it might be then the engine might be Mercury also. The engine could bring $300+. Rod
Old 01-02-2013, 11:03 PM   #11
Rowdy
Only BB if it has a 4 cyl. Rod
Old 01-02-2013, 11:06 PM   #12
DavidG
DavidG's Avatar
It's a '33, judging from the cab (integral firewall and two mouldings around the back), hood grille she,ll, and headlamps and headlamp bar.
Old 01-02-2013, 11:08 PM   #13
al's28/33
al's28/33's Avatar
It's a 1933 cab with a '34 grill no doubt. don't let it get away too cheap. Contact Joe Davis with ARIES Restorations, he is located up along Skyline Hwy 9. You can also search him on this site. He can see the truck in person and try to give you a reasonable estimate of what you have and how you can sell it. On his site, ARIES, you'll see a '33 panel delivery similar to the front end of this that he restored.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 01-02-2013, 11:29 PM   #14
Bob C
Rod, Tom's right that is a propane carb you can see the regulator in the last picture.
Bob
Bob C is online now   Reply With Quote
Old 01-02-2013, 11:31 PM   #15
Rowdy
Thanks, I was thinking it might be the later merc carb abd that was a rigged up airfilter. Sometimes I am right, sometimes I am wrong, but always trying. Rod
Old 01-02-2013, 11:31 PM   #16
Fordors
That is a '34 grille as stated earlier; it has stainless around the bars, '33 did not. To my eye the head light lenses look flat, with no crown. The bar is correct but looks like someone fitted '30-'31 Model A lamps to it. The '32 commercial bar had a high crown and the lamps are very high in relation to the grille. '33 & '34 bars are flatter and as a result the bottom of the lamps are lower than the bar. Lamps pictured are high, you can almost see the bar.
Fordors is offline   Reply With Quote
Old 01-03-2013, 01:03 AM   #17
FlatheadTed
FlatheadTed's Avatar
Interesting Vehicle ,The Carb looks to be purposes built for CNG or propane .Wonder how she went on that gas .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-03-2013, 01:05 AM   #18
pat in Santa Cruz
pat in Santa Cruz's Avatar
Hi Lilyduck
I just sent you a private email.
Pat
pat in Santa Cruz is offline   Reply With Quote
Old 01-03-2013, 01:36 AM   #19
Chris Haynes
Chris Haynes's Avatar
It appears to be a '32/'33. If the firewall bolts into the body it is a '32. If it is welded in it is a '33.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-03-2013, 08:42 AM   #20
Special Coupe Frank
Did the '34 Cab have rear-hinged doors ? ( Or am I thinking Dodge-Brothers ?)
