Old 11-14-2011, 08:11 PM   #1
Mike in Mass
Mike in Mass's Avatar
Default 40 starter rebuild
hey there . My dad let my sister take the 40 sedan for the weekend ,,,came home on a AAA TRUCK She must have hit the starter button ,while driving ,ate a MOST of the teeth , . but couldn,t get it started again after shutting it off . . pop pulled the starter and wants to send it out too the "STARTER GUY" on the "fordbarn". . he,s hoping for an easy fix and that the flywheel isn,t toasted . really don,t want to pull the motor . car is all original ,never been F,t with .got it from a little ol lady up in Maine 46,000 miles . all the under pans are still on it . anybody have a guy(or girl) in mind . thanks from 'POP' and me M in M
Mike in Mass is offline   Reply With Quote
Old 11-14-2011, 10:05 PM   #2
MuskegonFlatheadFan
MuskegonFlatheadFan's Avatar
Default Re: 40 starter rebuild
If the flywheel checks OK, Macs has new bendix/gears here:
http://macsautoparts.com/early-v8-st...0R3CHL1076123/
MuskegonFlatheadFan is offline   Reply With Quote
Old 11-15-2011, 08:16 AM   #3
G.M.
There are 2 flat headed bolts, one on each end of the spring that hold the spring in place check the bolts and the spring to make sure that nothing is broken. Take a set of battery jumper cables and see if the starter will run, put 2 nuts on the threaded stud and the black cable on the nuts and touch the red (pos) cable to the body of the starter and it should run. Hold the starter tight as it will torque or try to turn as it starts to turn. Look in the pan hole where the starter bolts on with a flash light to see if the teeth are damaged. I doubt all the teeth are gone, it would have turned the engine some until it got to the missing teeth. G.M.
www.fordcollector.com
Old 11-15-2011, 06:41 PM   #4
Mike in Mass
YEA GM , one of the bolts and spring is broken ,talked to him today . he,s looking for somebody to send it to ,,to fix . thanks for the replies guys . anyone know where he can send it mp
Old 11-15-2011, 09:21 PM   #5
G.M.
Mike here's the best place to send starters, generators or alternators. You won't believe how inexpensive it will be. They have been there for years and have all the parts needed. You can get the spring, lock washers and bolts and easily replace them, the two bolts are not the same, one is longer and go's down into the shaft. Chestnut Hill Auto Electric Denver, Pa. 1-717-445-4616 G.M. By the way I was born in Arlington.
Old 11-17-2011, 08:45 AM   #6
biggeorge
biggeorge's Avatar
i lived on forest st in arlington
biggeorge is offline   Reply With Quote
