04-22-2014, 03:24 PM | #1 |
heater fan motors
Is there anyone who repops the motor for the old hot water heaters. Any modern day ones to look for at the wreckers?
04-22-2014, 04:06 PM | #2 |
Re: heater fan motors
There is an old wrecking yard in Casa Grande, Arizona that has cars that are all pre 1959. They may be able to help you. They are; Desert Valley Auto Parts 800-905-8024 Give them a call. They may be able to help.
04-22-2014, 04:27 PM | #3 |
most all heater motors have the same bolt pattern, just check fan rotation, and all fords up till 55 used 6v motors, if using 12v on a 6v motor just run the motor on low, it will think its being run on high
04-22-2014, 07:31 PM | #4 |
napa has them single speed you will need to shorten shaft no big deal ..6 volt # 655 1021-12volt 655-1022,about $30 you can use a rheostat to control speed
04-22-2014, 08:25 PM | #5 |
Thread Tools | |
Display Modes | |
