09-27-2016, 05:01 PM | #1 |
Double Action Fuel Pump
Hey, Guys,
I'm a model A guy, but a friend, without computer access, recently bought a '51 F 1 pickup. It had an electric fuel pump but he wants to make it original. We took off the electrical and the mechanical pump was still on the truck but unhooked. We understand it is a "double action" pump (whatever that means.) Evidently it provides some extra vacuum. Can this pump be rebuilt? Does the truck really need this kind of pump? Would a regular mechanical pump from a V8 flathead work? Us Model A guys don't really speak fuel pump. What can you tell us? Marty |
09-27-2016, 05:14 PM | #2 |
Re: Double Action Fuel Pump
Is this what it looks like?
Bob |
09-27-2016, 05:33 PM | #3 | |
09-27-2016, 05:36 PM | #4 |
The double action fuel/vacuum pumps are still available from parts sources and kits are available too. They can be rebuilt but you have to find a rebuilder that has kits compatible with modern ethanol mix fuels. The vacuum pump backs up the windshield wipers. It's handy to have but not absolutely necessary.
09-28-2016, 06:40 AM | #5 |
Thanks for your input. My friend is sort of a purest, and when I phoned him and told him of the results from my inquiry he decided to go with a new double action unit. My "A" has vacuum wipers so I'm used to the way they work. Just sayin'
Marty |
09-28-2016, 10:32 AM | #6 |
09-29-2016, 12:05 AM | #7 |
for modern fuel proof diaframs and carb rebuild kits call this number 1 203 360 5945 his name is Ken ct, xlnt carb builder and has good parts
09-29-2016, 12:43 AM | #8 |
I was thinking about installing a double action pump on my '51 Ford to help with the wipers. I even went so far as to buy one, but when I checked on a couple forums, I saw warnings that they are hard on push rods and the lobe on the cam because the load is essentially doubled. Since I don't really like to drive in the rain that much, it is still sitting on the shelf. Has anyone else heard this, or had any experience with it? I think Mercury's had DA pumps, so maybe they had special pushrods? Any feedback will be appreciated.
09-29-2016, 03:12 AM | #9 | |
Had one on my Merc. and it was never satisfactory. The double pumper was a misguided attempt to correct the deficiency's in the vacuum wiper system. I installed electric wipers to cure the problem.
09-29-2016, 06:54 AM | #10 |
Not sure what that is referring to, if it was not original to the Truck how is putting an accessory back on being purest? I would think being purest would be to put a normal fuel pump back on. If you like the double pump nothing wrong with that, but I wouldn't equate it with be a purest.
09-29-2016, 07:16 AM | #11 |
Somewhere I have a Ford srvice bulletin warning about the aftermarket ones being hard on the cam lobe. This was from 48 or 49. I thought it funny because as someone said they went to this as an attempt to correct the intermittent wiper problem.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
09-29-2016, 07:26 AM | #12 |
When the double action pumps are working properly, they are fantastic. To show how good they are. I have a 1959 Ford prefect with (now) a 997 cc (61 ci) engine. This has vacuum wipers. Now with a tiny engine like this vacuum is very quick to disappear, any little acceleration operation would pretty much stall the wipers. Bung any kind of grade at it, its no wiper time. I fitted a dual action pump, identical to the V8 ones except the operating arm. Now these wipers don't slow down at all, ever. I love them as I can adjust the speed of the wipers down to hardly moving, better than intermittent wipers. Any speed from stop to going like the clappers.
Trust me, if the pump is in good fettle, they are amazing. I'd put one on my pickup in a heart beat it the electric ones pack up. I fitted the two speed electric ones a while back before I'd found out how good the vacuum stuff can work. The spring tension in these is quite a bit more than double the single action, but no where near the tension of the valves and lifters acting on the camshaft. Martin. |
09-29-2016, 08:41 AM | #13 |
Not all mercury cars came with the dual action pump. The two 51 Mercs I have were both assembled in Saint Louis and they were patterned for the dry western states so they just came with a standard pump. I imagine they were kind of a dealer add on in the dry states but may have been standard in the wet ones.
09-29-2016, 09:53 AM | #14 | |
And the parts book does list a single pumper that specifies for California use.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-29-2016 at 10:01 AM. |
09-29-2016, 10:57 AM | #15 |
My first car was ordered by a dealer in Garden City, KS and My 2nd one was ordered by a dealer in Clovis, NM so that probably was what made the difference. Both areas have consistently low rain fall per annum. Both cars were made within a month of each other in November of 1950. They are equipped with identical early type drive systems and accessories but have different trim & paint colors. They both have the 7RA pump. I know my Pop's car never had a replacement but the other car I can't be completely certain. The previous owner kept all repair receipts from the day they purchased it until around 1970 so anything could have happened after that. The last NM registration was in 1996.
