10-19-2014, 12:19 PM | #1 |
Front adjustable coil over shock question
Been wanting to lower the front of my 46 Mercury about 3 or4 inches. A buddy of mine has a couple of sets of coil over adjustable shocks. Was thinking of taking a few leaves out of the front springs until I get it down there and using the coil overs. Anybody have any experience with this set up? I've used them or rears with ladder bars and four links but never on the front. And never with leaf springs. I want this to be a driver that I plan to drive a lot. Any suggestions to make it work, or abandon it and use the dropped axle, spring and steering arms?
10-19-2014, 12:50 PM | #2 |
Re: Front adjustable coil over shock question
You probably already know the "good" answer. The coil-overs don't make for a realistic mix-n-match with the Mercury leaf spring, most-especially on the front. Go the tried n' true method with dropped axle and or springs......you'll be much ahead of the game. DD
10-19-2014, 01:28 PM | #3 |
There isn't (probably) a 4" gap between the existing axle and the frame or bump stops, so how can you lower it 3-4" and still have suspension travel for a daily driver? The coulover idea sounds like a really bad idea to me, the shock mounts aren't designed to support the weight of a heavy car like that.
You could go a couple of inches lower, but more than that would need a dropped axle. Fitting a dropped axle isn't necessarily a painless bolt-in. There are a series of knock on jobs that need doing (or problems to be solved, depending on your viewpoint). Mart. |
10-21-2014, 11:55 AM | #4 |
