Old 11-04-2011, 02:05 AM   #1
TimTheToolMan
Default 35/36 ford coupe/fordor driver/passenger door WANTED
City: CONYERS
State: GA
Price: ?????
In search of a pair of good doors pefer to be complete and original / for a 36 5 window coupe thankx for all u guys lookin out.....
TimTheToolMan is offline   Reply With Quote
Old 11-04-2011, 05:48 AM   #2
Tom Morookian
Tom Morookian's Avatar
Default Re: 35/36 ford coupe/fordor driver/passenger door WANTED
Ya' better figure out exacly what you need. 3 window doors are unique and only fit 3 window coupes. If my memory serves me correctly ( and it seldom does) 5 window coupes and 2 door sedans are the same. 4 door sedans are unique.
There's a pair of doors on ebay now ( not mine).
I have a very good, solid bottom, 5 window passenger door that is complete with the window/regulator/latch. Some dings in the panel.
I've got $550 in it and would sell it for that now that my coupe is complete. I'm in Ft. Myers Fla so you gotta' come and get it. Crating and shipping would be a pain and probably cost several hundred dollars. I would not trust Greyhound not to crush it but that's your call. Probably around $100.
Pictures if your interested?
Tom Morookian is offline   Reply With Quote
Old 11-04-2011, 07:48 AM   #3
Sid the Maineiac
Sid the Maineiac's Avatar
5w coupe and front doors from a 4 door sedan are the same with a little modification
to the top -rear of the 4 door door.2 door sedan and 3w coupes are the same from bottom up to where the window appears where you crank it up. The top part has to be built.Clear as mud?
Sid the Maineiac is offline   Reply With Quote
Old 11-04-2011, 07:51 AM   #4
richard crow
35/36 5 window coupe doors. 35/36 4 door sedan doors will fit but you have to grind the top radius to make them fit. 35 & early 36 doors both sedan & coupe have the inside handles in different locations then later 36 doors .35/36 two door sedan doors will not fit a coupe but the lower half can be used to repair a caborlet door. i don,t know any thing about 3 window doors except the top half is very different you don,t get to work on 3 window coups as they are very rair
richard crow is offline   Reply With Quote
