Old 08-14-2022, 10:35 PM   #1
Don/WI
Default Clutch release bracket
The Nickle A Region of MARC had our annual Corn Roast today. On the trip home one of our members had the misfortune of breaking the clutch release bracket located on the lower shaft that passes thru the bell housing. i volunteered to help with removing the broken part and installing a new (or good used) one. Can anyone tell me the easiest way to remove the existing rivet and broken bracket? I would be very greatful for that information. Thanks. Don/WI
Don/WI is offline   Reply With Quote
Old 08-14-2022, 11:49 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Clutch release bracket
Not sure what Clutch Release "Bracket. Are you referring to the clutch release arm as the one in the picture? Pretty common for them to break.
I just tapped out the pin with a hammer and punch and tapped in a new pin after replacing the arm. Hope that helps
Old 08-15-2022, 06:09 AM   #3
nkaminar
nkaminar's Avatar
If the rivet has a head on it, center punch the rivet and carefully drill it with a small diameter drill (1/8 inch) to about 1/4 inch depth. Then use a drill bit the same diameter as the rivet. That will remove the head of the rivet. Then use a punch and hammer to drive out the rivet.
Old 08-15-2022, 09:13 AM   #4
Don/WI
Thanks, that's the information that I was looking for. Don/WI
Old 08-15-2022, 09:14 AM   #5
Don/WI
Yes, that is the part. Thanks, Don/WI
Old 08-15-2022, 10:01 AM   #6
Y-Blockhead
Unless it is an early car it should have a drive pin, not a rivet. https://www.snydersantiqueauto.com/p...9050&cat=41664
Old 08-16-2022, 10:57 AM   #7
katy
katy's Avatar
My '31 CCPU has a bolt with a nut through it.
Old 08-16-2022, 12:16 PM   #8
The Master Cylinder
The Master Cylinder's Avatar
Not originally but I suppose that would work if the bolt fit in the hole(s) tightly.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
