06-28-2022, 08:31 PM | #1 |
Used cam value?
I replaced the cam in my rebuilt engine with a Stipe cam. Now I have a chance to sell the original cam. What would be a fair price? Thanks. Don/WI
06-29-2022, 06:00 AM | #2 |
Re: Used cam value?
You need to measure the bearing journals on the camshaft. When new, the journals measure. 1.559" - 1.560". I do not know what is the serviceable maximum wear, if worn significantly, the buyer's engine will need bushings put into his engine.
Bob Bidonde |
06-29-2022, 07:30 AM | #3 |
Re: Used cam value?
It is hard to imagine an original cam having the likely amount of wear on the center journal would have much value. Measure and reveal the size before selling. Good Luck: Fred A
06-29-2022, 07:43 AM | #4 |
Re: Used cam value?
it has value as a used cam if it is in good USABLE condition.
if the bearing surfaces and lobes are within rebuildable spec it has value as a core. and you can not buy an exchange cam without a rebuildable core. the specs for those should be on a suppliers website. what the value is? i dont know. if it is out of spec, give it to the recycle gods.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
06-29-2022, 12:19 PM | #5 |
Re: Used cam value?
Most cam shops will not regrind one if the center journal is less than 1.557".
06-29-2022, 12:33 PM | #6 |
Re: Used cam value?
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 06-29-2022 at 01:05 PM. |
06-29-2022, 02:50 PM | #7 |
Re: Used cam value?
value? not much..............
might buy a couple of Hershey bars. |
06-29-2022, 03:37 PM | #8 |
Re: Used cam value?
at swap meets i pick them up and don't pay more than $10-$15 ea. Because i'm buying an unknown and generally i don't have the measuring tools with me.
06-29-2022, 04:03 PM | #9 |
Re: Used cam value?
Interesting, would like to see a picture of this guy with the camshaft wrapped around his neck after trying to pawn it off on the wife as lamp.
06-29-2022, 04:52 PM | #10 |
Re: Used cam value?
Humans can produce 5 million cars but can’t visualize five million camshafts Ford produced? If a cam is 24” long, Ford produced 1894 miles of camshaft..
Laid end to end model a complete cars would stretch across the country.. 5 WIDE Last edited by jack backer; 06-29-2022 at 05:01 PM. |
06-30-2022, 08:47 AM | #11 |
Re: Used cam value?
I changed out my cam last year, if someone wants it I would just give it to them if they wanted to swing by and pick it up, that's the value I put on a used cam...I changed it out for a reason.
06-30-2022, 11:59 AM | #12 |
Re: Used cam value?
I usually carry a caliper at swap meets, but the value to me is the same as above. I sell reground cams, sometimes to people all over the world, and charge them a $35 core charge if they need one. I've had friends give me cores, and usually throw half of them away because of bearing size.
06-30-2022, 12:26 PM | #13 |
Re: Used cam value?
The journals can be sleeved back to standard but it does not become cost effective at
$200 each until the supply runs out. |
06-30-2022, 12:30 PM | #14 |
Re: Used cam value?
I gave my used cam away to a guy in our club that rebuilds engines. He had it re-ground. Journals were OK.
