03-12-2014, 12:26 PM | #1 |
Firestone Tires rubbing service brake rod
I just put 4 new Firestone whitewalls on my 31 roadster. I noticed that if I crank the steering wheel all the way to the right the tires will just touch the service brake rod on the passenger side. When I turn all the way left they clear the driver side brake rod by about an 1/8"
Has anyone experienced this and is there a quick fix? I searched the forum and couldn't seem to find any threads that talked about this issue. |
03-12-2014, 12:29 PM | #2 |
Re: Firestone Tires rubbing service brake rod
My driver's side rod rattled across my Goodyears. The rod was slightly bent away from the centerline of the car.
Straitened the rod (as they all should be) no more issues. Are your tires standard sized?
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
03-12-2014, 12:33 PM | #3 |
They are standard 4.75/5 19". Order them from Tam's in MA as stock replacements.
03-12-2014, 01:36 PM | #4 |
Does your king pin wedges have castellated nuts? Could be the tie rod....where
the steering box is not "centered", make sense? |
03-12-2014, 01:54 PM | #5 |
Check your king pin wedges, there is supposed to be a lock washer then then crown nut.
mike |
03-12-2014, 01:57 PM | #6 |
03-12-2014, 02:13 PM | #7 |
The castellated (actually closer to Acorn nuts) go to the rear. And depending on your specific year/front axle, the acorn part may be taller or shorter. Maybe about an inch long or so average? (Early Kingpin wedges may even show another nut on the front side - this castlelated with a cotter pin.)
Early in my Model A experience I renewed the Kingpins. With the kit came a couple of "ordinary" nuts to be used with the new retainer wedges. Which I dutifully put on. Gosh would that allow me a close turn - I could turn around 180 degrees in my father's garage, perhaps a 20 foot space? But it did allow the wheels to hit the brake rods. Still, I left it like that for a while since I could put the A over in the corner, and get two additional cars into the usual spaces. There used to be some talk about the 21" Firestones being a bit "larger" than other tires in overall circumfrence. As I don't own these I haven't had a chance to confirm this. The firestones also were reported to hit the fender brace similarly. Joe K
Shudda kept the horse. |
03-12-2014, 02:13 PM | #8 |
Thanks for the help.
03-12-2014, 02:17 PM | #9 |
You should start off with the steering box centered and go from there. You could
end up taking off the tie rod.....a pain. That's were I'd start. Dudley |
03-12-2014, 02:17 PM | #10 |
At the risk of raising the ire of the site, there is no such thing as a "Castelated" nut or even a "Castle" nut. The proper term is Crenellated. Just a point of fact, not meaning to be a pain.
The term comes from the nuts resembling the look of crenelations on the top of medieval castle and town walls which were defensive positions built into the walls.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
03-12-2014, 02:26 PM | #11 |
Are your front spindle bolt locking pin nuts in front of your front axle or are then in the back of the axle? If they are in the front (like my huckster) the tires will rub on the brake rods. If they are in back, they stop the wheel from turning to far. See page 11 in the Bratton's catalog drawing. It is part number 8. Good luck.
Fred Kroon 1929 Std Coupe 1929 Huckster |
03-12-2014, 02:30 PM | #12 | |
I'm just using the terms that Ford used and also the JS..... |
03-12-2014, 02:36 PM | #13 |
How about that.
SLOTTED HEX NUT A castellated nut, also called a castle nut or slotted nut, is a nut with slots (notches) cut into one end. The name comes from the nut’s resemblance to the crenellated parapet of a medieval castle. |
03-12-2014, 02:37 PM | #14 |
They're in front, so maybe that's an issue.
03-12-2014, 03:04 PM | #15 |
Never heard of them called by the name Crenellated.
Castellated nut From Wikipedia, the free encyclopedia Jump to: navigation, search Castellated nut A castellated nut, also called a castle nut or slotted nut, is a nut with slots (notches) cut into one end.[1] The name comes from the nut’s resemblance to the crenellated parapet of a medieval castle. (Bob beat me to it!) More on the subject: NASA 'Reference Publication 1228 March 1990 . _- Fastener Design Manual Castellated nut.—The castellated nut normally has six slots as shown in figure 6(a). The bolt has a single hole tirough its threaded end. The nut is torqued to its desired torque value. It is then rotated forward or backward (depending on the user’s preference) to the nearest slot that aligns with the drilled hole in the bolt. A cotter pin is then installed to lock the nut in place as shown in figure 6(b). This nut works extremely well for low-torque applications such as holding a wheel bearing in place.
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 03-12-2014 at 03:21 PM. Reason: Add info |
03-12-2014, 03:12 PM | #16 |
I believe that is the problem with Firestone's tires they are larger then the Goodyear. I had the same problem with my roadster that had Firestone tires,, it did rub on the drivers side brake rod. Goodyear no problems.
03-12-2014, 03:29 PM | #17 |
Just because Wiki and Nasa use the word doesn't mean it is correct. You need to consider the etymology of the word.
The term Crenellated is actually the correct term as it comes from the reference to the crenellations on castle and town walls in medieval times as previously mentioned.
03-12-2014, 03:31 PM | #18 |
Hi Fishercat, great handle by the way. I am next door to you in Alton, iff'n an extra set of eyes might help, let me know.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
03-12-2014, 04:02 PM | #19 |
Who cares about the true name of this nut! Must still have cabin fever.
03-12-2014, 04:04 PM | #20 | ||
