07-21-2012, 08:37 AM | #1 |
Update on Dim headlights & Repair
Well here is the update. Cleaned everything, all areas of ground, wires, NEW Sockets, bolts, washers etc... Put in halogen SAME EXACT THING.. DIM...terrible! and did i mention i am on an NUREX alternator also.
NEXT: PUT in 50/32 standard bulbs from Brattons .... BETTER than PERFECT. Brights glowing, running all working incredible!! LOVE it... BUT why the halogens that i have always used are not working...Very frustrating (and YES the bulbs work they are all NEW....what say you all now????
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
07-21-2012, 08:52 AM | #2 |
Re: Update on Dim headlights & Repair
Where were the bulbs made? Quality!!!
www.whidbeymodelaclub.com |
07-21-2012, 09:57 AM | #3 |
Is there any possibility that you got 12 volt bulbs by mistake?
07-21-2012, 10:14 AM | #4 |
Did you ever do the first suggestion and run a jumper lead from the left (drivers) lamp housing to a good ground such as a head nut to see if it brightened?
http://www.abarnyard.com/ |
07-21-2012, 05:59 PM | #5 |
Yes Marco and NO difference at all, has me very puzzled on why the 50/32 work great and the Halogen i get about 2 CP now???
07-21-2012, 07:49 PM | #6 |
07-21-2012, 08:18 PM | #7 |
Have you tried putting power to the bulbs while they are out of the sockets with
a couple jumper wires and a battery? Bob |
07-21-2012, 08:37 PM | #8 |
see you just can,t inprove on Henrys set up. Wounder as suggested 12v on 6volt set up , maybe incorrect lable , anyway least you are sorted , Could have sworn it was a weak earth,
07-21-2012, 09:56 PM | #9 |
Exactly MY thoughts and hope, YES with wire to the bulb they are great.. This is very puzzling to me...
07-21-2012, 10:04 PM | #10 |
Put the stock bulbs in, and measure the voltage from ground to each side of the bulb.
Then do the same with the halogens. This will show you where the voltage drop is occurring. |
07-21-2012, 10:06 PM | #11 |
ok that was one of the first things we did.. check the voltage and we are getting the full six volts....???
07-22-2012, 05:31 AM | #12 |
Something has to be happening in the socket then when you insert the bulbs if you've got 6 volts at the socket and the bulbs work when voltage is directly applied..........................What happens if you swap the bulbs L to R or vice/versa??
Paul in CT |
07-22-2012, 10:09 AM | #13 | |
Now, if the problem occurs with only one beam of the bulb then it's in the wiring and most likely a breakdown due to lack of soldering at a wire end (repro wiring isn't soldered like original). If the problem persists with BOTH high and low beams then I'd say the odds are about 99% that one of your tests was faulty and you still have a grounding problem. In your other post you said "BUT i did notice when the bulb is in and on and i push on it, it gets brighter AND then dims". Does that still happen? are you saying that it dims when you release it or that when you apply pressure it brightens but while maintaining pressure it fades back to dim?
07-22-2012, 11:46 AM | #14 |
When you get 6V on one side of the bulb, what do your read on the OTHER side of the same bulb?
Also, I doubt it is "6V". It is probably 6 point something. |
07-24-2012, 03:22 AM | #15 |
i have had a bad earth inside a bulb once. soldered it up and it was ok but i broke the bulb soon afterward.
07-24-2012, 03:36 AM | #16 |
Give this a GOOD read:http://www.danielsternlighting.com/t...ys/relays.html and add relays to the system.
07-24-2012, 05:57 AM | #17 |
Relays shouldn't be needed and I wouldn't add more complication to a simple circuit. In the Army I worked on control panels for missle launchers and they even had relays to engage relays. That made no sense to me, but that's what happens with government contracts and someone has stock in a relay company.
07-25-2012, 09:38 PM | #18 |
Well, Mark...it looks like I'll be going down that path soon, since I bought the same bulbs as you....
J Silvestri |
07-26-2012, 02:09 AM | #19 | |
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
