05-27-2016, 01:27 PM | #1 |
1934 Sedan roof tack strip...
After wire brush and vacuum, the black fibrous material in the tack channels is mostly gone leaving some around the standing rivets and inside the lips. This is a patina car so I can't see drilling out all those rivets and installing some type of replacement strip. Is there a fibrous adhesive or roof sealer that would dry and set up so as to use as a tack strip for tack nails or staples...
05-27-2016, 01:55 PM | #2 |
Re: 1934 Sedan roof tack strip...
It will be interesting to see what ideas come up here. On my own 34, I tried to do a 'patch-job', and I've regretted it. If and when I do it again, I will remove EVERYTHING in that channel, and start over. In my opinion, tack nails or staples aren't going to cut it. Especially if you use some sort of 'patch-job' material (combined with whatever is left of the original 'petrified' material). I did one of these using 4-40 screws threaded into the channel material, and I did another one where I used sheetmetal screws. The sheetmetal screws were not a good idea - leaves sharp, pointed end of screw exposed, and I ground these all off, especially in the area where my head might contact them. I also daubed the exposed screw-ends with RTV, so that they will hopefully do less damage to my head, if I contact them. The screws went through the original trim-strip that goes over the top material, so the top material is sandwiched between the metal trip-strip, and the channel.
Also, on the one I did with sheetmetal screws, I customized the screw heads, making the head diameter small enough to fit into the trim strip. A time-consuming custom job. I hope someone offers better ideas... |
05-27-2016, 02:57 PM | #3 |
There's a liquid filler that is used to repair horse's hoofs that is obviously nail-able and works wonders in repairing damaged body wood and top bows. It's expensive, but it works. I have to call to get the name to be certain of it and will post it this evening.
05-28-2016, 02:03 PM | #4 |
After some thought I think that the 2-part adhesive that present day body shops use to attach roofs (without welding) may be the trick. I believe it never gets rock hard....panel bond.....
05-28-2016, 08:55 PM | #5 |
