Old 05-16-2016, 03:12 PM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Front motor mounts 32-36
How do I tell the year on the 32-36 mounts? I know there is a little differance on the angle where the hose goes on. Is there a cast no, on the mount? Thanks Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 05-16-2016, 03:24 PM   #2
bobH
Default Re: Front motor mounts 32-36
some have cast number, some do not. I've got a pair of 33-34, and one has the cast number, the other does not. Of course, 32 is unique, and is easily identified just by looks. 35-36 could look similar to 33-34, and I can't help with visual features. Maybe deuce-lover? 32 is unique because 32 has the separate 'strut' for the motor mount, and there is NO mount built into the water inlet. 33-36 all have a motor mount built into the water inlet.
I think there is an exception for early 33. David G would be the one to address that.
bobH is offline   Reply With Quote
Old 05-16-2016, 03:31 PM   #3
bobH
Here are 33-34 mounts, in case this helps any....
Old 05-16-2016, 04:34 PM   #4
Don Rogers
Don Rogers's Avatar
Here are the 35 and 36 engine mounts.
Don Rogers is offline   Reply With Quote
Old 05-16-2016, 06:35 PM   #5
Walt Dupont--Me.
Great pic guys, I'll check mine tomorrow. Thanks. Walt
Old 05-16-2016, 07:10 PM   #6
DavidG
DavidG's Avatar
The first photo is of the three known varieties for '32 V-8s. In the second photo, bottom center, is the early '33 version used with the early front cross member with 12" spacing between the center lines of the motor mount insulators on the cross member. It is shown upside down.
