Old 04-30-2016, 07:13 AM   #1
lotsagas4u
Default Reproduction 34 front water neck/motor mount?
Does anyone make a repro water neck/motor mount for the early engines?
lotsagas4u is offline   Reply With Quote
Old 04-30-2016, 07:20 AM   #2
G.M.
Default Re: Reproduction 34 front water neck/motor mount?
I don't know of any but if yours is damaged by rust it can be
repaired by brazing it. G.M.
www.fordcollector.com
Old 04-30-2016, 07:47 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I have an original set, R & L sides, that I will be adding to my list of items for sale here in the early v8 swap classifieds as soon as I take some pictures for the ad.
John
Old 04-30-2016, 02:48 PM   #4
bobH
I've also got a set available.
Also, Charley-NY, who posts here, once posted that he was doing a repair on them. In any event, the old ones can be fixed.
bobH is offline   Reply With Quote
Old 04-30-2016, 03:10 PM   #5
Floyd
I believe the water inlet part is the same size as 32. In that event, a brass sink tailpiece will slide right into the inside of the inlet, it even has a nice rolled lip. This can be held in place with J-B Weld. Also the J B Weld is used to resurface the outside. When done ,you have a brass liner for the water side and a smooth pit free outer surface for the hose. My 32 inlets went from bad to looking brand new. Low cost fix.
Just my opinion
Floyd is offline   Reply With Quote
