Old 06-19-2012, 08:21 PM   #1
twilder
twilder's Avatar
Default Hand Cranking
If hand cranking a model A, do you crank clockwise or counter clockwise while facing the front of the car?
twilder is offline   Reply With Quote
Old 06-19-2012, 08:24 PM   #2
Mitch//pa
Default Re: Hand Cranking
Clockwise, start at 6:30 o'clock and pull to 11:45 o'clock , keep your thumb on the outside of the handle or your arm will end up in your ---------
Watch video.
https://www.youtube.com/watch?v=cDqPu...e_gdata_player
Old 06-19-2012, 08:25 PM   #3
Louis
The hand crank will only engage clockwise.
Louis is offline   Reply With Quote
Old 06-19-2012, 08:26 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Ok then, when facing the radiator, which hand are you supposed to use to engage the hand crank?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-19-2012, 08:52 PM   #5
Louis
You can use your left foot if you wan't ..., It's still clockwise facing the radiator .
Old 06-19-2012, 08:58 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Be sure the spark lever is full UP or you'll know it on the first fire.
Old 06-19-2012, 09:39 PM   #7
tbirdtbird
and be doubly sure you are in neutral with the hand brake set or the car will run you over and ruin your day.....it has happened many times ....
tbirdtbird is offline   Reply With Quote
Old 06-19-2012, 10:29 PM   #8
w.michael
w.michael's Avatar
Left hand. Then WHEN it kicks back, your forearm is less likely to be in the way.
w.michael is offline   Reply With Quote
Old 06-19-2012, 10:51 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
twilder,
Was this thread intended just to amuse yourself? We're not a bunch of idiots!! Get Real!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-19-2012, 10:55 PM   #10
Charlie Stephens
If you can crank your engine in either direction something is wrong. Looking at the front of the engine you should be able to crank it clockwise. Turning it counterclockwise should push the crank out of the front of the engine. If this doesn't happen there will be a big problem when the engine starts and the crank spins with the engine.
Charlie Stephens
Old 06-19-2012, 10:55 PM   #11
Franchise_24
Franchise_24's Avatar
Originally Posted by BILL WILLIAMSON View Post
twilder,
Are you ever happy? So much anger in most of your replies. Why is this? It appears this Ford Barner had a legit question. Just because you know the answer doesn't mean everyone else does. Get real!!
Franchise_24 is offline   Reply With Quote
Old 06-19-2012, 11:10 PM   #12
BILL WILLIAMSON
I'm NOT angry, I try to check the validity of everything I read. Some things prove TRUE, and some are unadulterated BUNK. Bill W.
Old 06-19-2012, 11:28 PM   #13
John Duden
John Duden's Avatar
AMEN!! i was cranking a 1929 McCormic Deering 1530 and it kicked me and cracked my wrist
John
John Duden is offline   Reply With Quote
Old 06-19-2012, 11:56 PM   #14
Tom Wesenberg
John
When I was in high school my first outboard was a big old Evinrude Speeditwin, which is a large opposed twin where both cylinders fire at the same time (lots of torque). I wrapped the rope around the pulley and gave a pull, but forgot to retard the spark. I thought it was going to shoot me right out the back of the boat!
Old 06-19-2012, 11:59 PM   #15
Milton
Milton's Avatar
When I was 15, I weighed in at a whopping seventy pounds, that is exactly the way I would do it. Set the crank at 1:00, face the drivers side and get on the bumper with my left foot on the crank then put my weight on the crank. It only kicked back once and I never used that method again, ever.
Milton is offline   Reply With Quote
Old 06-20-2012, 12:04 AM   #16
Franchise_24
My dad's had his car for longer than I've been alive (and I'm 33) and I know that it's only been hand cranked one time since he's had it just to say it was done. I've heard horror stories of trying to hand crank a car. People getting their hands broken and all kinds of bad stuff!
Old 06-20-2012, 12:44 AM   #17
J Franklin
J Franklin's Avatar
I had a '16 T with no starter so I got good at cranking, thumb under and never go over the top.
Old 06-20-2012, 01:05 AM   #18
james hitchcock
james hitchcock's Avatar
I still have a scar on my right hand index finger at the knuckle from pulling up hard on my crank and slipping. My knuckle caught the edge of the fender where it meets the edge of the radiator splash apron. Yeoooocchhh !!!!
james hitchcock is offline   Reply With Quote
Old 06-20-2012, 06:54 AM   #19
Gary/IA
Gary/IA's Avatar
Default Re: Hand Cranking - Dumbest trick ever
When just a very young person (6), I decided to crank an F-20 Farmall. Didn't have enough strength to pull the crank through so set it at 3 o'clock and jumped up on it an hung over the crank. The weight of my body pulled the crank down and the engine started.
Needless to say, I could have been the 1st person in orbit way back in 1947.
That's one I would like to forget, especially the reaction it got a few minutes later.
Gary/IA is offline   Reply With Quote
Old 06-20-2012, 07:56 AM   #20
Bob-A
Bob-A's Avatar
Thumbs up Re: Hand Cranking
On the "make sure the spark lever is retarded" statement. Let me add that if you have a good friend (like mine) near by. Be very leary of them
advancing the spark just as you go into spinning the crank! It is one of
the "funny" pranks we like to pull on each other with his Model-T's.
Back when I was in high school I had an original '29 Chevy. Once when
the starter Bendix spring broke I had to do a lot of hand cranking. It
was especially annoying if I stalled the car at a red light. I would jump out of the car grabbing the crank handle as I went. Run to the front, stick in the handle and most of the time I was lucky. She would fire up
before I was through the first spin cycle. Nobody ever got mad and started honking their horn. I guess they enjoyed the show and times
were easier on the road back in the mid 60's.
Bob-A
Bob-A is offline   Reply With Quote
