Old 09-15-2014, 02:59 PM   #1
TJ
TJ's Avatar
Default '40 cowl vent
I'm putting together my 40 cowl vent mechanism and I need to know the sequence of the washers on the spring loaded bolt that passes through the lever arm and the bracket. There's three washers that are about 1 inch in diameter. One has friction ridges on one side of it, then there is a thin brass washer and last is a regular flat washer.
Old 09-15-2014, 03:12 PM   #2
geoford41
geoford41's Avatar
Default Re: '40 cowl vent
Bob Drake sells the hardware kit for $25 and says it contains a "killer 6 page instruction booklet" may be worth it to have new hardware plus detailed instructions
geoford41
geoford41 is offline   Reply With Quote
Old 09-15-2014, 03:51 PM   #3
TJ
TJ's Avatar
Geo, thanks. I'll look in the new catalog.
Old 09-16-2014, 11:05 AM   #4
Bob Drake Repro
Bob Drake Repro's Avatar
TJ, this earlier thread may help...
https://www.fordbarn.com/forum/showthread.php?t=40854
Bob Drake Repro is offline   Reply With Quote
Old 09-16-2014, 03:26 PM   #5
TJ
TJ's Avatar
Bob Drake team, thank you for the link to the discussion. I talked with Cole yesterday and ordered the hardware kit with instruction sheet. Now with the instruction sheet I can get a jump start on the installation before the kit arrives. Thanks again. Tom
Old 09-16-2014, 03:34 PM   #6
supereal
supereal's Avatar
Check the Drake cowl vent gasket. We had some problems in years past with the gaskets being too thick to allow the vent to close completely.
supereal is offline   Reply With Quote
Old 09-16-2014, 07:06 PM   #7
TJ
TJ's Avatar
That may be part of the problem I'm having. I don't know who's gasket it may be as it was in the car when I got it.
Old 09-17-2014, 12:42 PM   #8
mike42
mike42's Avatar
SuperReal is correct. I had the same problem and had a friend shave it down 1/16". Fit good after that.Seals great now.
Mike
mike42 is offline   Reply With Quote
