Old 01-13-2013, 11:18 AM   #1
Ken B
Ken B's Avatar
Default C-Cab body
I am hoping to be able to build a C-Cab delivery body like the one in the attached pictures. Is it better to use a steam box to bend the pieces of wood in a jig or just cut the curves on a band saw leaving open end grains in the wood?
Ken B is offline   Reply With Quote
Old 01-13-2013, 11:32 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: C-Cab body
I would steam the wood and let it dry in a jig.
Old 01-13-2013, 11:37 AM   #3
Maclab58
Maclab58's Avatar
Make a steam box. You will have less trouble with the wood splitting over time. Not to mention less waste of materials.
Maclab58 is offline   Reply With Quote
Old 01-13-2013, 09:39 PM   #4
Ken B
Ken B's Avatar
Thanks for the replies. What kind of wood is preferred for a body like this? Is oak better than ash?
Old 01-13-2013, 10:09 PM   #5
Vic in E-TN
If you steam Oak it will turn black.
Vic
Vic in E-TN is offline   Reply With Quote
Old 01-14-2013, 12:55 AM   #6
pat in Santa Cruz
pat in Santa Cruz's Avatar
ash was the preferred wood for auto and truck body frames. It is strong and flexible. Ash was at one time cheap and plentiful as well. Oak was sometimes used during shortages of ash.
A simple steam cabinet can be made from a 4 inch PVC pipe. Cap the ends with reducer bushings and pipe the steam in through a smaller pipe.
pat in Santa Cruz is offline   Reply With Quote
Old 01-14-2013, 01:57 AM   #7
Mike V. Florida
Mike V. Florida's Avatar
This is a 2" copper tube in which water is boiling in while having the wood inside.
