08-31-2013, 08:12 AM | #1 |
flathead heat sending units
I have several flathead heat sending units and would like to identify them for the years they originated. Any Barners know of a list that shows the matching numbers? Thanks.
08-31-2013, 12:05 PM | #2 |
Re: flathead heat sending units
The single terminal type is the 8A-10884 and the double terminal is the 8A-10990. If you plan to sell them, I suggest testing them first to make sure they work. We had a handful of NOS senders that were no good. The brand new senders work ok, so if they don't test good, pitch 'em.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
08-31-2013, 01:27 PM | #3 |
What is the procedure for testing them? Thanks
John |
08-31-2013, 01:58 PM | #4 |
This may help. Info. is from 1949-51 Vol.2 of Mercury Overhaul Manual. I bet these interchange with FORD to some degree.
08-31-2013, 02:22 PM | #5 |
Here's how you test them. FORD is the same. Click on pic. to enlarge.
08-31-2013, 02:24 PM | #6 |
08-31-2013, 03:13 PM | #7 |
19fordy,
Thanks for your efforts to post this test. I will print it out. John |
08-31-2013, 04:54 PM | #8 |
Not interested in selling them. Simply want to match up a pair for a 1946 59AB engine that is in going in my 40PU.
Prior to using, is their a preliminary resistance or continuity check that would spot a bad sender? Thanks. |
08-31-2013, 08:33 PM | #9 |
Kent the double terminal one would be same as an on off switch. 0 ohms when cold, and open cirrcuit when hot.
I can't tell you about the single termial one. Did I read somewhere that there are two different single terminal ones? BTW, 19Fordy's posted pictures cover the test procedure. Thanks 19Fordy! Last edited by Bluebell; 08-31-2013 at 08:41 PM. |
