08-18-2013, 08:52 AM | #1 |
Ignition resistor
Preparing to rewire the 1940 Ford pickup I am building and noticed that the ignition resistor is missing on the breaker assembly board. (Two wires hanging.) I've read that the ballast resistor should be 1.5 ohms, but I see in the Macs catalog that their 32-48 ignition coil resistor is listed as 40 ohms. Any Barners know what the proper ohms should be? Thanks.
08-18-2013, 12:40 PM | #2 |
Re: Ignition resistor
I see macs has that 40 ohms but think its wrong.
.4 would be more correct. Say 3 amps x.4=1.2 volts leaving 5.8 at coil +or- Ford used a .5 ohm resister. 1.5 ohms more for 12 volts if you used that one your coil voltage would be to low. |
08-18-2013, 01:31 PM | #3 |
