Old 03-18-2013, 08:12 PM   #1
ford1948f1
Default No compression
Hi everyone, I have a 1948 ford f1 v8 flathead with no compression on 4 cylinders. I have removed the heads and intake and valves are free, what could cause this. I was told from Previous owner that the truck was running fine with no problems but due to his health condition he had it park for 9 years.
ford1948f1 is offline   Reply With Quote
Old 03-18-2013, 08:20 PM   #2
Rock Hornbuckle
Rock Hornbuckle's Avatar
Default Re: No compression
Are the 4 cylinders on the same bank?
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 03-18-2013, 08:51 PM   #3
ford1948f1
No 2,5,6,7 no compression
Old 03-18-2013, 09:01 PM   #4
Rock Hornbuckle
One on passenger bank and three on driver's bank. Engine sat for 9 years. What do the valve seats look like, and what is the compression, zero?
Semper Fidelis
Old 03-18-2013, 09:14 PM   #5
36Bill
36Bill's Avatar
You have to move air to get compression, could it be plugged intake or exhaust?
Bill
36Bill is offline   Reply With Quote
Old 03-18-2013, 09:27 PM   #6
ford1948f1
Valves seem to be fine, the gauge just moves up and down from 0 to 5 psi, I was trying to start it all i would get was backfire threw the carb, I rebuilt the carb.
Old 03-18-2013, 09:29 PM   #7
ford1948f1
How could I clean the valves?
Old 03-18-2013, 09:33 PM   #8
VeryTangled
VeryTangled's Avatar
Hi, Not a motor guy, but if the valves are happy then the rings would be the next likely culprit. I assume you're getting a good fit on the compression gauge.
-VT/Jeff
Old 03-18-2013, 09:54 PM   #9
Rock Hornbuckle
Give us the readings on all 8 cylinders.
Semper Fidelis
Old 03-18-2013, 10:05 PM   #10
ford1948f1
Cylinder 1 100 psi
Cylinder 2 0 psi
Cylinder 3 95 psi
Cylinde 4 95 psi
Cylinder 5 to 7 0 psi
Cylinder 8 90 psi
Old 03-18-2013, 10:25 PM   #11
Rock Hornbuckle
It would seem that your gauge was working, therefor most likely it is the compression rings that need to be replaced. Mic the cylinders, check for wear. You may need to rebuild the engine if the cylinders are worn. How many miles on the engine?
Semper Fidelis
Old 03-18-2013, 11:38 PM   #12
Lanny
Lanny's Avatar
The valve has to mate properly in the valve seat (NO rust or corrosion anywhere)
and make sure the valves arn't burned or compression cannot build.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is online now   Reply With Quote
Old 03-19-2013, 01:23 AM   #13
denver9
After sitting so long without running there is a good chance the valves are stuck due to rust and corrosion. I am not familiar with flat head V8's but i assume there is a valve cover on the side of each bank. If so, remove the covers, turn the engine over and see if the valve stems are moving freely. That may reveal the pproblem.
denver9 is offline   Reply With Quote
Old 03-19-2013, 07:52 AM   #14
Mike51Merc
Mike51Merc's Avatar
Zero compression indicates open valves more than bad rings. Bad rings will generate at least some compression.
Mike51Merc is offline   Reply With Quote
Old 03-19-2013, 08:48 AM   #15
chuck stevens
chuck stevens's Avatar
valve covers ...!!!! rocker-arms? Maybe check the ECM, just a thought.
chuck stevens is offline   Reply With Quote
Old 03-19-2013, 09:01 AM   #16
krackerjack1951
krackerjack1951's Avatar
most likely carbon under the valves..pretty common condition....hand rotate the engine ,when each valve is at its highest.a tooth brush type wire brush with a little kerosene or diesel fuel scrub the seats in the block and each troubled valve..clean them up and ck compression again..if the compression improves,you might get away with lapping the valves....poor fuel,,short trips doesnt heat the engine enough to burn off the carbon..on and on!
krackerjack1951 is offline   Reply With Quote
Old 03-19-2013, 09:17 AM   #17
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Those valve covers must be collecter items. Henry Ford is still looking for them. LOL Walt
Old 03-19-2013, 09:20 AM   #18
1931 flamingo
1931 flamingo's Avatar
ARDUN.......................
Paul in CT
Old 03-19-2013, 09:42 AM   #19
Mike51Merc
Mike51Merc's Avatar
What's a valve cover?
Old 03-19-2013, 09:47 AM   #20
Ronnie
Ronnie's Avatar
Valve train seems to be where problem lies is.You should always have the correct valve in the compression tester as a tire valve is incorrect.Tire valve is not sensitive enough.
R
Ronnie is offline   Reply With Quote
