Old 12-27-2011, 07:01 AM   #1
Junknshit
Banned
Default Longest doors???
Am trying to piece together a "phantom" (never made) body style out of discarded model A parts and am wondering which model A body style had the longest doors? 28-9 or 30-1 doesn't matter.
Thanks
Junknshit is offline   Reply With Quote
Old 12-27-2011, 07:53 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Longest doors???
Well, since you are speaking of a phantom, it would probably be the 155C Wagon, or the 255C Delivery, which both shared the same door. They both were somewhere in the 48¼" range if my memory is correct.
Ohh, ...and "nice" username.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-27-2011, 02:19 PM   #3
Jordan
Jordan's Avatar
Longest as in height or width? Cause I thought a-400 doors were the widest.
Cowtown A's
Jordan is offline   Reply With Quote
Old 12-27-2011, 02:23 PM   #4
LukeDahlinger
Might as well say Victoria/A-400 doors since they are the same.
How about the 180A door, that's a pretty wide door.
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 12-27-2011, 02:27 PM   #5
peters180a/170b
peters180a/170b's Avatar
180a doors are the longest ...
peters180a/170b is offline   Reply With Quote
Old 12-27-2011, 03:43 PM   #6
Junknshit
Banned
OK, how about which closed car has the widest (front to rear) doors?
Ohh.... that has been my nick name for many many years Brent.
Old 12-27-2011, 07:10 PM   #7
BRENT in 10-uh-C
While it may be your nickname, I sure there are places where some folks don't say it outloud. In your defense, maybe you are never in those places.
As for Victoria/400A doors, decent ones will generally set you back in the $800-$1000 range for the pair due to their rarity. Then you need to use a slant-windshield cowl section which are usually a little more expensive over a straight-windshield cowl section.
While I am not condoning you building a hot rod or cutting up a car (since Ryan wants us to use this forum only for discussing Restoration, --not Rods), the easiest & cheapest method would likely be to find a pair of 'pre-May 1931' Fordor Sedan doors off of a Briggs and graft the two together, and then use sheetmetal to make the infrastructure where the wood originally was. More of those bodies around than will ever be restored.
BRENT in 10-uh-C
Old 12-27-2011, 08:36 PM   #8
V4F
V4F's Avatar
try "tudor" doors ............ steve
V4f
V4F is offline   Reply With Quote
Old 12-27-2011, 09:18 PM   #9
Vanspeed
Vanspeed's Avatar
I think you should try to find some doors to make out of two like brent said. Since it is a phatom, you can make them how you like. Leave the a-400 doors alone and make two long doors out of some briggs doors.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 12-27-2011, 11:15 PM   #10
Deluxe Delivery Don
Deluxe Delivery Don's Avatar
Maybe you thought they said, "JUNKNSHIT" , Maybe they said "JUMPINSHIP"
Deluxe Delivery Don is offline   Reply With Quote
Old 12-28-2011, 11:19 AM   #11
Junknshit
Banned
If I had 10 A400 doors, I wouldn't use one where it didn't belong. I am building this out of parts that were headed to the scrapyard after a nice trip thru the crusher. The doors I use will be junk also. Although, with the attitude I see about a name, makes me almost want to whack up restored A's.
Brent, As far as places I have or haven't been, not important, what I am is what's important to me. You don't see me passing judgement down.
Thank you Steve. I appreciate the info, and I'll look for some junk doors.
Old 12-28-2011, 12:44 PM   #12
BRENT in 10-uh-C
Well, lets see ...., you come to a forum where the topics are supposed to be solely about 'Restoration', which I believe you even posted in a specific thread (#86) where Ryan told you what we would discuss here. How is building a "phantom" tie in with restoration under Ryan's rules?
And you choose a username that contains a word that most readers/posters here do not say/use publicly here. The real world is all about making judgment calls ....and you are correct that most won't see you passing judgment. I do however think your comment regarding how you would almost like to whack up restored Model A's says a lot.
BRENT in 10-uh-C
Old 12-28-2011, 01:16 PM   #13
Junknshit
Banned
WOW......................All I did Brent is ask a question about Model A doors.
It is plain to see that you have a problem with me.
To put an end to this I will not post on this topic any more.
Old 12-28-2011, 01:39 PM   #14
BRENT in 10-uh-C
(I sent you a PM if you would like to respond.)
BRENT in 10-uh-C
