10-16-2015, 06:33 PM | #41 |
Re: Fords in the Fall
10-16-2015, 07:03 PM | #42 |
Looks almost as good in B&W
Thanks again 47COE
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
10-16-2015, 07:25 PM | #43 |
Old Henry, Did you figure out your rough running at altitude problem with the 47?
10-16-2015, 07:31 PM | #44 |
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
10-16-2015, 11:38 PM | #45 |
I've ordered a new coil resistor to replace that as some testing has indicated that may be the problem. We'll see. The problem no longer seems to be altitude related or even heat related. It's just one of those weird random things.
10-16-2015, 11:50 PM | #46 |
https://www.youtube.com/user/roosty6/videos |
10-17-2015, 10:09 AM | #47 |
It is hard to believe that raising the hood a crack would have anything to do with a coil resister problem. I would at least try removing the air cleaner to see if the air flow may have some effect especially since you are not running an original type carb. I tried a modern type air cleaner element on my Stromberg 97 and it caused it to run too rich. Just a suggestion.
10-17-2015, 10:45 AM | #48 |
10-17-2015, 11:20 AM | #49 | |
10-17-2015, 01:53 PM | #50 |
You nail it.......!!
Whether you think that you can,or that you can't,you are usually right....H.Ford |
10-18-2015, 04:00 AM | #51 |
Great thread, favourite time of year and favourite cars.
Zach, I would like to see more of your 35. Gordon. |
10-21-2015, 09:41 AM | #52 |
As close to fall conditions as it gets in Southern California.
10-21-2015, 09:56 AM | #53 | |
-WANTED-
10-21-2015, 10:10 AM | #54 |
The more I learn about new automobiles, the more I value my old ones. Last edited by sidevalve8ba; 10-21-2015 at 02:47 PM. |
10-21-2015, 01:42 PM | #55 |
ZEPHYRING in the Fall, Huron River rd Ann Arbor Mi...and Hidden Lake Gardens in Irish Hills Mi..last month just before leaves change..
10-23-2015, 09:54 AM | #56 |
The leaves here aren't as colorful as past falls, but here is a picture that I took yesterday. Pat
10-23-2015, 03:55 PM | #57 |
Picture taken Oct 24 09. Car is six years older, looks exactly the same now buried in my garage.
10-23-2015, 07:51 PM | #58 |
1932 Ford BB - Madison, NJ - 2015
10-23-2015, 10:50 PM | #59 |
Penobscot Narrows Bridge and Observatory U.S. 1, Stockton Springs, ME Oct 2015
Last ride for the season |
10-24-2015, 06:51 PM | #60 |
