08-06-2015, 10:48 AM | #1 |
The last and the first
Ever notice how it is ALWAYS the last thing that you do to try to fix a problem that actually fixes it? Whether it's the first thing you try, the 6th, or the 12th, it's always the very LAST thing you do that fixes it. And, too frequently, the ultimate solution to the problem is the simplest thing that you actually thought of first but dismissed as too simple and easy.
I just went through that with my fuel delivery problem on a 51 Custom I'm trying to sell for a friend. My first thought was vapor lock but I tried my usual quick diagnostic fix for that and it didn't work so I went on to replace the gas cap, replace the fuel pump, replace the fuel lines from the tank to the flex line and from the pump to the carb, and replace the flex line with one from Shewman with a check valve in it. None of it fixed the problem. So, what was I left with but to return to possible vapor lock? With some additional and more exhaustive and thorough testing such proved to be the problem all along from the start and was fixed with an electric fuel pump. The last thing I did fixed it which was the first thing I thought of.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
08-06-2015, 10:54 AM | #2 |
Re: The last and the first
OLD HENRY ..........................
Of course, it's the last thing you do, that fixes the problem. After yo fix it, you are not going to try to fix it, again ! It's just like, when you lose something, it's always found in the last place, you looked. MIKE (mikeburch) |
08-06-2015, 11:08 AM | #3 |
So, there you go, responding to the profound with simplicity.
The response I had hoped for was, "Gee, I never realized that. That is amazing how that ALWAYS works. I wonder why that is."
08-06-2015, 11:23 AM | #4 |
Lol
08-06-2015, 11:30 AM | #5 |
It's like when you lose something and it's always in the last place you look.
Glad you fixed it. Mart. |
08-06-2015, 11:38 AM | #6 |
Glad you were able to eliminate that issue on a beautiful car. Someone will be able to enjoy owning and driving a good old car. Wish it was me. Bruce
Works good Lasts long time |
08-06-2015, 11:42 AM | #7 | |
08-06-2015, 12:14 PM | #8 |
Last night I found what I was looking for in the second place I looked. I was rather pleased with that.
08-06-2015, 12:21 PM | #9 |
Serves me right not to skim read.
08-06-2015, 03:12 PM | #10 |
Yes, Seth. It was right where you left it.
It's always the back-tracking that's difficult |
08-06-2015, 03:34 PM | #11 |
Would one of you please tell me where my safety glasses are. They disappeared from the back seat of my car after my last trip to the storage unit to finish the distributor install.
08-06-2015, 03:39 PM | #12 |
08-06-2015, 03:46 PM | #13 |
I'm still having dreams about that 51 . . . .
08-06-2015, 05:10 PM | #14 |
Gee, I never realized that. That is amazing how that ALWAYS works. I wonder why that is?
08-06-2015, 08:14 PM | #15 |
I was just about to say the same thing!
Amazing how that works out! I'll have to puzzle out why that is! |
08-06-2015, 08:19 PM | #16 | |
08-06-2015, 08:25 PM | #17 | |
A. Second to the last place. B. Second to the first place. C. First to the last place. D. B. & C. E. A. & B. F. A. & C. G. All of the above. H. None of the above. I. I don't know.* J. I don't give a darn.^ BTW, did you know that Hu really is on first? * Third base. ^ Short stop.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 08-06-2015 at 08:35 PM. |
08-06-2015, 08:28 PM | #18 | |
If you ask my wife she'll tell you. "Right where you left them." (Yeah. So, where was that?)
08-06-2015, 08:51 PM | #19 | |
I glad you cured the problem. The thing that bothers me is the video you posted of the trail of bubbles in the clear tubing. Is the heat source causing the vapor lock condition the under hood temps or the exhaust pipe heating the fuel line from the tank? It is also possible there is a leak in the fuel line that allows air to be drawn in when the pump is pulling fuel when the engine is running. I would be inclined to monitor the fuel line to be sure no fuel is leaking under pressure from the new electric pump.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
08-06-2015, 08:54 PM | #20 | |
