Old 07-21-2015, 06:32 PM   #1
Old Henry
Old Henry's Avatar
Default Type F tranny fluid for 51 Custom?
Hey, I'm new to this 51 Custom so need to ask some dumb questions. O'Reilly says Type F for this automatic transmission. Is that right?
Old 07-21-2015, 06:46 PM   #2
WestCoast
Default Re: Type F tranny fluid for 51 Custom?
that's the one
WestCoast is offline   Reply With Quote
Old 07-22-2015, 08:58 AM   #3
rotorwrench
rotorwrench's Avatar
There is also some types that are marked as type FA. Either will work for the Ford-O or Cruise-O type Borg Warner transmissions.
Old 07-22-2015, 09:46 AM   #4
Old Henry
Old Henry's Avatar
Yes. I see Valvoline calls theirs FA.
Thanks all for the info.
Old 07-22-2015, 03:29 PM   #5
Seth Swoboda
Seth Swoboda's Avatar
I missed something, when did you get a '51 custom and where are the photos?
Seth Swoboda is offline   Reply With Quote
Old 07-22-2015, 03:37 PM   #6
CT AV8
CT AV8's Avatar
Yeah, I was thinking the same thing.
Seth, the Prof probably took a short spin to check things out.... you know, like up to Edmonton and back.
CT AV8 is offline   Reply With Quote
Old 07-22-2015, 05:01 PM   #7
ccnelson
Did you find the fuel problem with the '51. Wondering the problem was?
ccnelson is offline   Reply With Quote
Old 07-22-2015, 05:09 PM   #8
JSeery
JSeery's Avatar
You must not have been following this!!! He is help someone out and there have been photos posted.
Old 07-22-2015, 09:39 PM   #9
Seth Swoboda
I see. Sorry I missed the aforementioned post. I though for a minute that Old Henry was going to start touring in a 51.
Old 07-23-2015, 10:00 AM   #10
Old Henry
Old Henry's Avatar
My friend that owned this 51 Custom passed away last month and just before he died he asked me to take his 51 Custom and sell it for him. See this thread: https://www.fordbarn.com/forum/showth...ight=51+custom
It was his understanding that the car has never been painted, upholstered, nor drive line worked. It had 63,000 original miles. Seems to me like it may well qualify for a three point Rouge award. Here's the story on that: https://www.fordbarn.com/forum/showth...ight=51+custom
Old 07-23-2015, 10:04 AM   #11
Old Henry
Old Henry's Avatar
The main problem with keeping it running when it warmed up was the fuel line. I had it replaced and now it runs fine, once it's started. I'm now having a problem starting it when it is hot. I believe it's vapor lock but it doesn't resolve when cooled. I've just ordered a flex hose with check valve from Bob Shewman to see if that helps. It's still not driving reliably enough for me to recommend it to buyers or to even drive it around town with For Sale signs on it.
Old 07-23-2015, 10:19 AM   #12
JSeery
JSeery's Avatar
Henry, is it boiling the fuel out of the carb when it sets hot?
Old 07-23-2015, 05:08 PM   #13
Old Henry
Old Henry's Avatar
No. Because the engine will start and run for a minute before it uses up the fuel in the carb but doesn't get any new from the pump.
