10-24-2022, 08:12 PM | #1 |
Oil pump replacement gears
The new gears seem to be made of sintered metal, which I understand is metal powder molded under high pressure and temperature.
Will the sintered metal replacement gears last as long as the original style gears ? thanks - Jim Last edited by Conaway2; 10-24-2022 at 08:20 PM. |
10-25-2022, 03:35 PM | #2 |
Re: Oil pump replacement gears
Hi Jim.
Sintered metal is porous, which significantly reduces strength. But it optimizes its own lubricity (which is irrelevant with an oil pump.) The load on the two conveyor gears is low, and sintered iron copes better with dirt getting between the teeth. Conclusion: Milled steel is significantly harder, sintered metal wears less.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
10-25-2022, 03:55 PM | #3 |
