Old 06-24-2010, 06:57 PM   #1
Ole Lou
Default front mount for 59ab in 32 frame
Will 32 v-8 front motor mounts work on a 59ab to be installed in a 32 frame?
Ole Lou is offline   Reply With Quote
Old 06-24-2010, 06:58 PM   #2
hotcoupe
hotcoupe's Avatar
Default Re: front mount for 59ab in 32 frame
Yes!
hotcoupe is online now   Reply With Quote
Old 06-24-2010, 08:09 PM   #3
Kahuna
Kahuna's Avatar
Hotcoupe is absolutely right, as long as you are using the original front cross member.
Kahuna is offline   Reply With Quote
Old 06-24-2010, 08:09 PM   #4
Andy
You will need 49-53 lower hoses.
Andy is offline   Reply With Quote
Old 06-24-2010, 09:04 PM   #5
thunderbirdesq
thunderbirdesq's Avatar
They worked for my 8ba.
thunderbirdesq is offline   Reply With Quote
Old 06-24-2010, 11:27 PM   #6
tub1
tub1's Avatar
if you look in the pic above you will see two motors 32 mounts even fit that other brand motor if you slot 2 of the mount holes slightly
tub1 is offline   Reply With Quote
Old 06-25-2010, 07:28 AM   #7
32Gnu
32Gnu's Avatar
Not meaning to Hijack here..
But, when I got my car(which was a 4cyl car originally) there was a v8 59ab motor installed and the water pump necks were about 4" from lining up vertically with the radiator necks. Almost like it needed a "S" hose.. The crank hole was lined up perfect with the crank. Is this because it was a 4 cyl crossmember or was there an offset hose?
Thanks in advance
32Gnu is offline   Reply With Quote
Old 06-25-2010, 08:25 AM   #8
thunderbirdesq
Thanks in advance
Not sure about a stock application, but I did make small "s" tubes for mine when I installed it. I think the difference between 4 and 8 was a width measurement between the mount pads. I'm gonna venture a guess that the stock '32 v8 lower inlet lined up better than the 59ab or the 8ba.
Old 06-25-2010, 10:01 AM   #9
Bruce Lancaster
Yes, '32 lower hose was straight! Common cranked hoses to work from are 1940 and 1949 Ford ones...
Mounts basically fit the late engine...you will probably have slight interference with edges of waterpums--I would grind the pumps simply because radically less valuable than the mounts.
The lower pump pulley location on the 59 requires a very slight mount notch to clear the belt where it goes past...if you fit this area carefully, the notch can be very slight and entirely on the inner edge of the mount forging. Too many out there have been roughly and excessivel ground because someone was too lazy to check and make multiple trips to the grinder...
Old 06-25-2010, 10:32 AM   #10
Bruce Lancaster
Except for fairly rare early 1932's, 4 and 8 front crossmembers are the same.
Old 06-25-2010, 01:04 PM   #11
Ken Arms
Ken Arms's Avatar
Not sure if this will apply to your 32 but I bought front motor mount adaptors for my 34 for a 59ab. from what im told ford even had a part # for them since many swaps were made back in the day. They are no more than a u shaped bracket that bolts to stock mount to raise engine slightly and line up to 59ab without cutting a slot. Ken
Ken Arms is offline   Reply With Quote
Old 06-25-2010, 01:32 PM   #12
Bruce Lancaster
Ford supplied those with a 41A number; the postwar parts catalogs show them in kits containing proper crank pulley, hoses, etc. to fit the 24 stud replacement engines into '36-back V8's. Useful back through 1933. '32 mounts work direct from block holes that remained the same '32-53, so did not need spacers.
