Old 03-11-2014, 04:48 PM   #61
Kube
Kube's Avatar
Default Re: What's causing this squeak?
Originally Posted by V8COOPMAN View Post
Lawrie...With ALL due respect ('cuz YOU do some nifty stuff), putting ANYTHING on that taper defeats the purpose of how a machined-taper is designed to function. It should go back together clean, dry and tight. Think about the physics of a MORSE TAPER. DD
Coopman, you are 100% correct about this. It was always amazing what a Morse taper could hold. I recalll clearly using a 6" drill bit in a vertical drill press... no problem holding it with a Morse.
One thing I'd like to add - the mating surfaces should be SMOOTH. Any marks remaining from polishing compound, etc. lessen the grip.
Old 03-12-2014, 12:03 AM   #62
Old Henry
Old Henry's Avatar
Originally Posted by Kube View Post
. . . the mating surfaces should be SMOOTH. Any marks remaining from polishing compound, etc. lessen the grip.
I wondered about that. Probably should have followed up with the fine grade compound. We'll see how it goes.
