01-19-2017, 02:51 PM | #1 |
Broken bolts
I just started taking an 8ba apart. This block only has the Crank pistons and the valve train. As I started working on it I found two broken head bolts and six broken ex. manifold bolts. Please advise
01-19-2017, 03:03 PM | #2 |
Re: Broken bolts
If you plan on taking this block to a machinist for work they will remove them easily.
01-19-2017, 03:06 PM | #3 |
Re: Broken bolts
Do you have a welder? If so, there are many threads about this. If you don't Seth has the right idea. I would strongly suggest not using EZ-outs, etc.
01-19-2017, 03:12 PM | #4 | |
Re: Broken bolts
Charlie Stephens |
01-19-2017, 03:29 PM | #5 |
Re: Broken bolts
I posted this over on the HAMB.
The method I have used is to weld a washer over the bolt and then a nut on top. It usually takes two trys ea for me. It may be the heat treat of the bolt. It has always worked.Do not get in a hurry. Gentle back and forth is the way to go. . I saw something on wax to loosen rusted bolts and desided to try it. I had a column drop and the pinch bolt was so rusted you could not see the threads where they were exposed. I heated the area a couple of time and just for curiosity, melted some wax everywhere it could get to the bolt. It sat overnight. The next morning I built up the head if the bolt and welded a washer and nut to it. I put Vice Grips on the nut and was prepared for a lot of heating and wiggling. The vice grips swung around. The bolt was not even finger tight. Completely loose. The threads in the drop and the bolt are fine. I am amazed. |
01-19-2017, 03:41 PM | #6 |
Re: Broken bolts
01-19-2017, 04:26 PM | #7 |
Re: Broken bolts
Be warned about "some" machine shops removing the broken bolts. I asked the machine shop to remove two for me because they were doing the machine work anyway. Instead of removing the broken ends they drilled them out and used helicoils to replace the threads. That caused me lots of grief. If you use a shop, be specific about what you expect.
01-19-2017, 04:40 PM | #8 |
Re: Broken bolts
thank you for that tip
01-19-2017, 05:34 PM | #9 | |
Re: Broken bolts
What was the grief with the heli coils? R |
01-19-2017, 06:12 PM | #10 |
Re: Broken bolts
01-19-2017, 06:13 PM | #11 |
Re: Broken bolts
Takes more time to remove it then install a helicoil usually so when they try and save you some money...a helicoil or thread insert should work fine if done right.
01-19-2017, 06:35 PM | #12 | |
Re: Broken bolts
Both will work well when installed correctly. R |
01-19-2017, 07:32 PM | #13 |
Re: Broken bolts
I would have more confidence in Helicoils installed in holes with stripped threads. Drilling out a broken bolt and getting the hole centered and straight is harder. I would worry that the stud would be angled or off center.
01-19-2017, 08:11 PM | #14 |
Re: Broken bolts
Nah. Us farmers have more confidence in 3/8-16 stud. Drill the broken bolt with a 5/16" bit as straight/centered as you can. Then tap the hole for the aforementioned stud as straight as you can. Jack E/NJ
01-20-2017, 04:10 AM | #15 |
Re: Broken bolts
Mike I have used the welding washer and nut idea for years. One tip, after welding let it cool down some and put your favorite penetrating oil on them and the should come right out. I like a 50/50 mixture of automatic transmission fluid and Acetone for penetrating oil.
01-20-2017, 08:47 AM | #16 |
Re: Broken bolts
Mike, here is a page from the Ford Garage. As Andy mentioned above. I have never had to remove one, but if I did, I would try this first. I have heard a few guys have done it and it worked well. Just my 2 cents. Good luck with it.
http://www.fordgarage.com/pages/studremoval.htm |
01-20-2017, 09:26 AM | #17 |
Re: Broken bolts
Thank you for all the info I am going to fire up my mig welder and mix up some penetrating oil.. Semper Fi MIke
01-20-2017, 10:10 AM | #18 |
Re: Broken bolts
No need for penetrating oil just quench the weld after with a candle and wait till the weld has cooled off that you can touch it.Depending on your skill set the first attempt may not get it,but don't be discouraged as it works very well.I have removed too many to count from 6/32" up to 3/4" with no problems,but I use a tig that gives much more heat control with a foot pedal as well letting you dwell on the weld for a long time to let the heat penetrate.
R |
01-20-2017, 12:17 PM | #19 |
Re: Broken bolts
Welding a washer and then a nut +adding candle will do the trick , just like above mentioned. Done that hundreds of times one different situations.
01-20-2017, 03:56 PM | #20 |
Re: Broken bolts
01-20-2017, 05:03 PM | #21 |
Re: Broken bolts
Wow. Washer and Nut! Really? Where have you been my whole life? I have been missing out HAHA.
01-21-2017, 09:36 AM | #22 |
Re: Broken bolts
Thank you all what a great bunch of people you are . MIke
01-24-2017, 08:46 PM | #23 | |
Re: Broken bolts
Cheers |
01-24-2017, 09:42 PM | #24 |
Re: Broken bolts
I had one a while back in a 99a where someone had drilled out the broken stud and then re-tapped it but it wasn't in straight!!, ended using an old head as a guide, by drilling the stud hole to the helicoil tapping size, bolting it on and using it as a guide
