01-26-2015, 08:14 PM | #1 |
99 Merc block done
I ended up with three of these blocks this summer. (all are .045 over bore) Completed this one today. 99 USA block factory relieved. Heads are Canadian Aluminum 91A. Did the aluminum peas and the tightest spot was .053 Gasket is .059 and I assume when compressed it is .050. That means my tightest spot over a piston will be .044. Had to mill the block .012 due to a gouge. Now I am wondering if one of these intakes would happen to be the right one to go with this setup. Thanks Bill
01-26-2015, 10:43 PM | #2 |
Re: 99 Merc block done
I'd say the middle one.
01-27-2015, 01:48 AM | #3 |
I have a 99a in my 33 at the moment,4 inch crank and .040 over bore,I used the 33/34 manifold and 97 carb, that engine has a pile of torque and is so nice to drive.
I know it could do with a bigger carb ,but where I do most of my driving it is very nice. lawrie |
01-27-2015, 09:35 AM | #4 | |
01-27-2015, 09:41 AM | #5 |
Bill,
The cast in raised 99 on the right deck makes that a Canadian block, doesn't it? US 99 had only a stamping on intake surface 1939/1940, if any. Does the flat intake surface date the block 39/40 as opposed to 41/42 (so called raised) as US blocks. Yours came from 1942?-- or is set up for crab distributor. Interesting variety of intakes---1939 or earlier? Nice build! Gene Tulsa |
01-27-2015, 12:44 PM | #6 |
01-27-2015, 12:59 PM | #7 |
I can't explain the difference in the heads, but I can say the '1' in 91A makes it a Ford part number, and the second '9' in 99A makes it a Mercury part number
01-27-2015, 01:15 PM | #8 |
My guess is that the combustion chamber would be a little larger. Since the engine is bigger, the chamber would be larger to keep a similar compression ratio.
01-27-2015, 01:17 PM | #9 |
The manifold on the right looks to be a 34 or early 35 manifold.
01-27-2015, 04:33 PM | #10 |
Bobh, Thank you for that information.
