Old 01-08-2015, 01:09 AM   #1
Ab4875
Ab4875's Avatar
Default Frozen motor - melting out pistons
I've got an old 8BA motor that's been out in the elements for several years with the heads removed. Its pretty close to junk but I want to salvage the conrods. The pistons are aluminium and are stuck. I've tried soaking in penetrant for a few weeks without any success.
I was thinking of trying to melt out the pistons with a gas torch. Has anyone tried this?
Ab4875 is offline   Reply With Quote
Old 01-08-2015, 01:43 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Frozen motor - melting out pistons
If you heat up the pistons you will just expand them. You would have better luck if you could fill the block up with very hot water. Have you tried the 50% acetone 50% auto trans oil for the penetrant? I think I would drill a lot of holes in the pistons and break most of the large pieces out to reduce the friction enough to move the crank. Too much heat might not be good for the small end of the rods you want to save if you used an acetylene torch. Just a few thoughts.
Old 01-08-2015, 02:15 AM   #3
Lawrie
Lawrie's Avatar
I have pulled a few engines like that apart,the trick if you want to save the bore or the rods is to use a 3/4 diameter bar about 2 ft long,then turn one end down to about 1/2,then from the top or the bottom of the pistons use a 2 lb hammer and smash the pistons apart,it works
Lawrie
Old 01-08-2015, 04:45 AM   #4
Brian
Brian's Avatar
Have you an engine re-builder handy? With a 'hot tank'? Simply drop the block into the hot tank and let the pistons dissolve!!
Old 01-08-2015, 07:08 AM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I have use a 2-1/2in. hole saw and cut the top of the piston off then you can break the sides off. Walt
Old 01-08-2015, 05:32 PM   #6
john hamilton
john hamilton's Avatar
Since you've soaked it take the crankshaft out. Get a piece of wood about the size of the bore and stick it into the cylinder. A big hammer should take care of it, probably without breaking anything. Watch that you don't drive the rod into the ground. You just need to get the piston moving with the hammer then you can be more gentle.
john hamilton is offline   Reply With Quote
Old 01-08-2015, 06:59 PM   #7
Bonus Built Acres
Bonus Built Acres's Avatar
I have gone this route a few times,
just watch the pilot bit so you don't drill too far into the connecting rod end... I've heard of that happening anyway, not that I'd know,
1951 F1 (pile of parts)
1952 F-6 what was I thinking? restoration-maybe
1929 Model A Roadster (original)
1945 Ford GPW (buried in the garage)
1953 C-600 MH, 1951 F2 MH, 1951 F3 MH
2 Kids, 3 Dogs, only 1 Wife!
Bonus Built Acres is offline   Reply With Quote
Old 01-08-2015, 07:19 PM   #8
Binx
In other words have another shorter pilot bit for the big finish.
Lonnie
Binx is offline   Reply With Quote
Old 01-08-2015, 07:20 PM   #9
Mike B
I soaked a L=head Dodge engine for a long time...couldn't move it either...I was however, able to drop the crank.
I had a 3/8ths slug of metals I had cut at some point, and fit inside the bore...now the Dodge pistons were flat. so I took my air chisel and fashioned a blunt blade for it, and rattled the piston to get it moving, then wood and a hammer got it out.
Mike B is offline   Reply With Quote
Old 01-08-2015, 08:30 PM   #10
Ab4875
Ab4875's Avatar
Thanks guys, I think I'll try the hole saw method.
Old 01-08-2015, 09:54 PM   #11
Clem Clement
Clem Clement's Avatar
I used a 2 inch diameter brass drift and a BFH and the pistons crumbled
Old 01-09-2015, 12:31 AM   #12
bobH
Careful with the bfh... I've got a broken cylinder wall to show for it
bobH is offline   Reply With Quote
Old 01-09-2015, 08:39 AM   #13
Ralph Moore
Ralph Moore's Avatar
I've tried getting the crank out of some stuck motors, but the problem I've had is you can't get to some of the Rod cap bolts due to their position. I've tried turning a hard to reach one and rounded off the corners.
So far lots of soaking and a good piece of hardwood and a big hammer have worked best for me.
Although I do know where there are about a dozen flatheads sitting in the dirt in a junkyard that would be a lot worse than any I've torn down.
I could probably get them all cheap, but I'm not sure I have enough time left to take on such a task
Ralph Moore is offline   Reply With Quote
Old 01-09-2015, 09:36 AM   #14
Admiral
Admiral's Avatar
Pops built a special drill guide that allows you to punch a series of holes through both the piston and rings to free things up. Once the tension is released from the rings the pistons often come out pretty easily. If not, you can always chip away at them with a cold chisel and carefully work them out that way. I'll see if I can grab a photo at lunchtime.
Admiral is offline   Reply With Quote
Old 01-09-2015, 10:20 AM   #15
corvette8n
corvette8n's Avatar
I had to use a cold chisel on a motorcycle motor once, after I busted out the piston it was as if the rings were welded to the walls.
Old 01-10-2015, 09:53 PM   #16
jake197000
i bought a ancient 1 cyl hit and miss engine that was stuck bad.thied everything.an oldtimer told me to stand cyl on end pour brake fluid ib it and a stick uf wood maybe1x1 light the brake fluid let it burn all day just keep topping off the fluid through the day.at end of day took a 4x4 and the piston came out.never hadto do a v-8 but maybe u could do 4 cyls at a time.it heats the block slowly and evenly.this block was probably350 lbs bare.i worked at this thing for a week before triying this.i was sooo happy.no damage.dit have to sleeve it due to rust.
jake197000 is offline   Reply With Quote
Old 01-11-2015, 03:05 PM   #17
3738
3738's Avatar
A few months ago, I acquired a stuck 1938 Lincoln Zephyr V12 that was stuck.
I mixed up the acetone ATF mix and soaked it 1st from the top, then from the bottom, but after weeks of soaking, no luck.
Next, I filled each cylinder with acetone and set them on fire. Repeated this numerous time and was eventually able to disassemble everything with no damage, other that an oil pump housing that broke in half getting it out of the bore.
I believe the heating and cooling cycles from the fires loosened up the pistons in their bores.
3738 is offline   Reply With Quote
Old 01-11-2015, 09:27 PM   #18
Ab4875
Ab4875's Avatar
Thanks guys for the tips. I've got all the pistons out.
I ended up removing the crankshaft and then pushing the pistons down the bores with a sledge hammer and 2-1/2" inch drift. A couple of them broke up around the skirt but they weren't usable anyway so that was fine.
One of the pistons bottomed out on the centre main journal. I tapped it back into the bore so the top oil ring lined up with the start of the cylinder bore. With it in this position I hit the skirt on the side with the sledge hammer and it sheared off nicely. I was pretty happy with that.
Thanks again for your help.
Old 01-11-2015, 09:48 PM   #19
26 lakes
I did a post back in 02/04/2012 "How to properly warm up a Flathead". Once you try this you will put your acetone, hole saw and your Big _ Hammer away. It will never fail. It warms up the sludge in the block and you can get your connecting rods out safely. It is safe. If you can cook on a grill, it is no different than lighting starter fluid.
26 lakes is offline   Reply With Quote
Old 01-11-2015, 10:40 PM   #20
cmbrucew
cmbrucew's Avatar
Here is a link to 26 lakes method. interesting read.
https://www.fordbarn.com/forum/showth...+warm+Flathead
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
