07-06-2015, 07:11 PM | #1 |
Chebby dist to replace 8BA
From what I have read on the barn here, one of the best ignition set ups is the Chevy distributor, adapted to the 8BA, Has anyone used the Petronix system in that distributor ? I did a search, and got some great information on setting up the vacuum and mechanical advance. Thank you Fordbarners.
07-06-2015, 07:29 PM | #2 |
Re: Chebby dist to replace 8BA
Match the Pertronix with the correct coil and it will be great.
07-06-2015, 08:17 PM | #3 |
whats wrong with the flatty dist I change points every 5000 miles not hard to do putting any chebby part on a ford is like being a bruce jenner
07-06-2015, 08:22 PM | #4 |
The original distributors will not work well (if at all) with a carburetor change or other modifications. The original does not have any counter weights and depends on the internal carburetor porting for ignition advance.
07-06-2015, 09:28 PM | #5 |
^^ haha Joe 1950 ^^
07-07-2015, 07:36 AM | #6 |
