07-04-2015, 08:23 PM | #1 |
Fuel Tank Sender
Thanks to Morris Gauge, Portland, Oregon, I know how much fuel I have.
My 1937 Ford fuel gauge did not register so I had purchased a repro sender -- it did not work. Thought the gauge was bad. I had kept the original sender with the shriveled up old cork float when I made the switch. Glad I did. I sent the original sender to Morris Gauge and they rebuilt it. I installed the rebuild and now the gauge works too. Now I know how much fuel I have. Thanks Morris Guage. I think someone here on Ford Barn had mentioned the company. Thanks. http://www.morrisgauge.com/ Last edited by TonyM; 07-04-2015 at 08:40 PM. |
07-04-2015, 11:11 PM | #2 |
Re: Fuel Tank Sender
Thanks for this info. I may get the sender rebuilt in the '39 pickup since I already have the rear end removed for work.
I like that '37 you have. |
07-05-2015, 01:36 PM | #3 |
Thanks Seth.
I was keeping a fuel log with mileage and gallons. Probably will continue with that to check the accuracy of the gauge. |
07-05-2015, 03:28 PM | #4 |
Just replaced the float on my sender with a float for a Model A. The cork floats get gasoline logged. A week later gauge did not work again. PO had spliced the sender unit line into the harness and had a bad connection. The system is pretty simple, just have to think out what could be wrong.
07-05-2015, 06:34 PM | #5 |
I have used floats from late model used senders that I get for free from the radiator gas tank shop. You have to modify the wire holder a bit but they work with modern fuels.
07-06-2015, 04:55 PM | #6 |
www.morrisgauge.com |
