Old 02-20-2011, 09:56 PM   #1
Peter J
Peter J's Avatar
Default Water in the oil.........still
Hey Guys,
Had water in my oil and suspected a cracked head. I was. Got a new head and had it trued and replaced it with a new gasket. New studs also. Everything was torqued back down per Les Andrews and fired her up.
Still getting water in my oil. I think I'm going to start looking for a new block rather than tearing this down again. I'm thinking I'm starting to throw good money after bad.
What Say Ye??
Thanks,
Pete
Peter J is offline   Reply With Quote
Old 02-20-2011, 10:22 PM   #2
Glenn C.
Glenn C.'s Avatar
Default Re: Water in the oil.........still
Not only did Model A engines crack at the rear to the outside, they also were known to crack in the valve chamber between #2 # #3 cylinders. They also will crack between the same two cylinders on the top deck, which might allow water into the oil when sitting.
Glenn C. is offline   Reply With Quote
Old 02-20-2011, 10:38 PM   #3
James Rogers
James Rogers's Avatar
You know it takes a while to get all the water flushed out. There is almost a quart in the valve chamber and the dipper tray. If you didn't pull the pan and clean out the valve chamber you will have water in your oil.
James Rogers is offline   Reply With Quote
Old 02-20-2011, 10:52 PM   #4
Peter J
Peter J's Avatar
James,
That's somewhat encouraging. I put 4qts. in and read just above the "F" on the stick. Now it's up about about 1/8" in 3 days of sitting. I replaced a valve when i did the head so the valve chamber is clean.
Pete
Old 02-21-2011, 05:45 AM   #5
James Rogers
Peter, let it sit for several days without moving it. Drain the oil and see if any water comes out when you first pull the plug. Water is heavier than oil so, it sinks to the bottom and will come out first. I don't like the increase in the level but this may just be your imagination playing tricks.
Old 02-21-2011, 07:55 AM   #6
kenparker
kenparker's Avatar
In addition to what James suggested, pull the valve cover off, wipe out all remmanents of oil - get it clean in there - and as it sits for the several days you can watch for evidence of water and where it is coming from - if it is cracked. Good luck and we hope you find no water.
kenparker is offline   Reply With Quote
Old 02-21-2011, 09:36 AM   #7
Peter J
Peter J's Avatar
Thanks guys. I appreciate the positive input. I was just hoping I could move on to working on the body etc. rather than be hung up on the engine. I'll drain off about a quart of "oil" and mark the dipstick. I did put a bottle of Bar's Leak to see if that may help as I can't go a replacement engine.
Pete
Old 02-21-2011, 09:44 AM   #8
Special Coupe Frank
Special Coupe Frank's Avatar
For a stop leak, try "K-Seal" - comes in blue bottle (mini anti-freeze jug shape), with an orange cap, retails for about $13/bottle.
Has worked great in my '28, and is not "gunky" like BAR'S Leak...
Special Coupe Frank is offline   Reply With Quote
Old 02-21-2011, 10:48 AM   #9
dfish2931nc
dfish2931nc's Avatar
Send a message via ICQ to dfish2931nc
I had a simular situation when I first got into Model A's. I had a cracked block between the valve seat to the piston. It only leaked when the engine got warm. Drove me crazy for a week. Changed heads twice before I learned what to look for from an older Model A'er. Good luck.
dfish2931nc is offline   Reply With Quote
